1 2 Previous Next 43 Replies Latest reply on Jan 7, 2019 3:52 PM by George_Johnson
    how do i populate a form with current date?
    rosemariem24343617 Level 1
      I tried the instructions below but it does not work:
      In Acrobat:
      The script you create to display the current date when the document is opened is a document level script.
      To create an automatic date field:1. Select Tools > Forms >. Edit > Add New Field > Text Field and create a text field. (For more infor-mation, see the section on Creating Form Fields in the Acrobat online help.) Select All Properties > General tab and name the field Today.
      2. Select the Format tab, chooses Date for the format category, and chooses a month, day, and year format option (for example, “mmm d, yyyy”). On the General tab, make sure the field is read-only because it will be a calculated field, and click Close.
      3. To create a document level script that is executed each time the document is opened, choose View > Tools > Document Processing > JavaScript > Document JavaScripts. Name the script Today, and click Add.
      4. Delete the automatically generated text, defining a Today function, that is displayed in the script window. Type in the following text in the exact format (line wraps are OK) and click OK.
      var f = this.getField("Today");f.value = util.printd("mm/dd/yyyy", new Date());
      This script binds the Today field to the variable f, and then calculates the value. The newDate() ex-pression creates a new date object initialized to the current date and time. The util object is used to format the date into the month/day/year format.
      5. Click OK in the JavaScript Edit dialog box, and then click Close in the JavaScript Functions dialog box.
        1 2 Previous Next
