2 Replies Latest reply on Apr 27, 2006 7:02 AM by MergeThis
    Looking for proper scripting for allowing context sensitive help with a .Net application
    Shawn_K._N.
      Hi. I am looking for help with the scripting that we should be using so that our context sensitive help works with our .Net application. The scripting we used to get the context sensitive help to work with our ASP application no longer works with the .Net application. Can anyone tell me what initial scripting we should be using to make our context sensitive help work with our .Net application? Thank you in advance.
      Sincerely,
      -Shawn
        • 1. Looking for proper scripting for allowing context sensitive help with a .Net application
          Roger N Level 2
          Shawn -
          Welcome!
          If you're using VBscript, the window.open() method will open a new window with a URL.
          • 2. Re: Looking for proper scripting for allowing context sensitive help with a .Net application
            MergeThis Level 4
            A search on .NET on the forum retrieved one of my posts on this subject from last year:
            Our developers name all forms (windows), tabs, and controls, and they call like-named WebHelp HTM files directly in a cascading drop-off style. For example, in this call for a Name drop-down selection field on the Main tab of an Admin window:
            adminmainmenu.admainmaintab.admainnameedit.htm
            the app looks for admainnameedit.htm first; not finding that, it looks for admainmaintab.htm next, then finally settles on adminmainmenu.htm (we're only using window-level help right now, but with all elements named we could go more granular anytime).
            Because our help is a merged WebHelp project, we also place a comma-separated formpath.txt file at the root, with entries like these to denote the projects (folders) where the app will find the topics:
            adminmainmenu, mergedProjects\admin
            Leon
