11 Replies Latest reply on Apr 2, 2016 10:15 AM by phoenix830
    Script to save as tif with zip compression, file name from properties
    phoenix830
      I don't know anything about scripting so I am unable to understand the answers to similar questions and merge an answer for mine.
      I am looking for a script to save my scanned images as tiff with zip compression using the Document Title from the file properties.
      I want to assign it to a button to save me time, Scanning images takes enough time as it is
      Thank you in advance for any help.
        • 1. Re: Script to save as tif with zip compression, file name from properties
          SuperMerlin Level 5
          Try this.
          #target photoshop;
          main();
          function main(){
          try{
          var Path = activeDocument.path;
          }catch(e){
              alert("This document needs to have been saved before running this script!");
              return;
          var fileName =activeDocument.info.title;
          if(fileName == '') {
              alert("There is no title in this document");
              return;
          var saveFile = File(Path + "/" + fileName + ".tif");
          app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
          function SaveTIFF(saveFile){
          tiffSaveOptions = new TiffSaveOptions();
          tiffSaveOptions.embedColorProfile = true;
          tiffSaveOptions.alphaChannels = true;
          tiffSaveOptions.layers = true;
          tiffSaveOptions.imageCompression = TIFFEncoding.TIFFZIP;
          activeDocument.saveAs(saveFile, tiffSaveOptions, true, Extension.LOWERCASE);
          • 2. Re: Script to save as tif with zip compression, file name from properties
            phoenix830 Level 1
            Thank you for the quick reply.
            I have tried the script but I need to save it before running the script. I was hoping to use the script as a Save as is that possible?
            • 3. Re: Script to save as tif with zip compression, file name from properties
              SuperMerlin Level 5
              This will prompt you for the output folder.
              #target photoshop;
              main();
              function main(){
              var Path = Folder.selectDialog( "Please select output folder");
              if(Path == null){
                  alert("You need to select an output folder!");
                  return;
                  return;
              • 4. Re: Script to save as tif with zip compression, file name from properties
                phoenix830 Level 1
                Thank you again. I am able to select to location but it doesn't save.
                I removed  app.activeDocument.close(SaveOptions.DONOTSAVECHANGES); because it just closed without saving. The location I am saving id D:\Scanned Images
                After figuring some of it out I got this from a different thread and the answer you supplied
                1. var fileName =activeDocument.info.title;
                2. var saveFile = new File("d:/" + fileName + ".tif");
                3. tiffSaveOptions = new TiffSaveOptions();
                4. tiffSaveOptions.embedColorProfile = true;
                5. tiffSaveOptions.alphaChannels = true;
                6. tiffSaveOptions.layers = true;
                7. tiffSaveOptions.imageCompression = TIFFEncoding.TIFFZIP;
                8. activeDocument.saveAs(saveFile, TiffSaveOptions, true, Extension.LOWERCASE);
                This creates the file as I wanted, The problem is I can not get a if else command to work like the one from your code  "
                    return;
                Was I right saving it as a .jsx I first saved it as .vbr but while trying to learn what I was reading I figured it was Javascript
                • 5. Re: Script to save as tif with zip compression, file name from properties
                  phoenix830 Level 1
                  On an other subject do you use Adobe Configurator?
                  I am using VueScan and want to speed up my scanning by using Adobe Configurator to create a easy access button. However the option isnt there. I was wondering if you knew what the script would be?  Below is the code for inserting a note. I think I need to edit the 'importAnnots' but not sure what to
                  ErrStrs = {}; ErrStrs.USER_CANCELLED=localize("$$$/ScriptingSupport/Error/UserCancelled=User cancelled the operation"); try {var idimportAnnots = stringIDToTypeID( 'importAnnots' );     var desc1085 = new ActionDescriptor(); executeAction( idimportAnnots, desc1085, DialogModes.ALL ); } catch(e){if (e.toString().indexOf(ErrStrs.USER_CANCELLED)!=-1) {;} else{alert(localize("$$$/ScriptingSupport/Error/CommandNotAvailable=The command is currently not available"));}}
                  • 6. Re: Script to save as tif with zip compression, file name from properties
                    phoenix830 Level 1
                    Sorry one more thing how would it deal with duplicates? I would like it to add a number on the end instead of overwriting
                    • 7. Re: Script to save as tif with zip compression, file name from properties
                      SuperMerlin Level 5
                      This should now as I have tested this version.
                      There is no prompt it just saves to the scanned folder.
                      Yes it should be a jsx file.
                      #target photoshop;
                      main();
                      function main(){
                      var Path = Folder("/D/Scanned");
                      if(!Path.exists){
                          alert(Path + " does not exist!");
                          return;
                          return;
                      SaveTIFF(saveFile);
                      • 8. Re: Script to save as tif with zip compression, file name from properties
                        phoenix830 Level 1
                        This overrides files with the same name is it possible to prevent this?
                        • 9. Re: Script to save as tif with zip compression, file name from properties
                          SuperMerlin Level 5
                          If the file exists this will append the time so it will be a different file name.
                          #target photoshop;
                          main();
                          function main(){
                          if(!Path.exists){
                              return;
                              return;
                          if(saveFile.exists) saveFile = File(Path + "/" + fileName +"-" + time() + ".tif");
                          SaveTIFF(saveFile);
                          function time(){
                          var date = new Date();
                              var d  = date.getDate();
                              var day = (d < 10) ? '0' + d : d;
                              var m = date.getMonth() + 1;
                              var month = (m < 10) ? '0' + m : m;
                              var yy = date.getYear();
                              var year = (yy < 1000) ? yy + 1900 : yy;
                              var digital = new Date();
                              var hours = digital.getHours();
                              var minutes = digital.getMinutes();
                              var seconds = digital.getSeconds();
                              var amOrPm = "AM";
                              if (hours > 11) amOrPm = "PM";
                              if (hours > 12) hours = hours - 12;
                              if (hours == 0) hours = 12;
                              if (minutes <= 9) minutes = "0" + minutes;
                              if (seconds <= 9) seconds = "0" + seconds;
                              todaysDate =  hours + "-" + minutes + "-" + seconds + amOrPm;
                              return todaysDate.toString();
                          • 10. Re: Script to save as tif with zip compression, file name from properties
                            phoenix830 Level 1
                            Goin to add a time stamp to the end of it when I look at it tomorrow changing the code adds numbers to the end will google time stamp then
                            var thistimestamp = Math.round(new Date().getTime() / 1000);
                              var saveFile = File(Path + "/" + fileName + "--" + thistimestamp +".tif");
                            SaveTIFF(saveFile);
                            Thank you for the time you have spent helping me
