2 Replies Latest reply on Apr 3, 2016 11:46 PM by marty_76
    Processing a folder of images with Applescript
    marty_76
      Hi everyone
      I am having a problem with my Applescript that I want to open a folder of images and process in PS.
      The script works fine on a single test image whose file path I hard coded to open, but after adding the looping section, I'm not sure I have the right set up to open each image.
      That part of my script is:
      set sourceFolder to "Users:etc:etc" as alias
      set destFolder to "/Users/etc:etc"
      --source and destination folders for the images
      tell application "Finder" to set imageSet to every file in sourceFolder
      tell application "Adobe Photoshop CS6"
        activate
        set ruler units of settings to pixel units
        repeat with i from 1 to (count of imageSet)
        set currentImg to item i of imageSet
        open currentImg
        (rest of the code to adjust the images)
        end repeat
      end tell
      The error i get is "Finder got an error: document file "(filename)" of folder "(folder name)" (the rest of the file path) of startup disk doesn’t understand the “open” message." when it halts at the 'open currentImg' command
      Just wondering if anyone could help me with this? Or offer some code that might work?
      Would be appreciated, as this is the last thing I need to do to finish the script and get the job completed.
      Thx in advance
      Marty
        • 1. Re: Processing a folder of images with Applescript
          greenrookie Level 3
          Try this.
          --Need to use Applescript file paths with colons for Finder
          set sourceFolder to "Macintosh HD:Users:etc:etc"
          set destFolder to "Macintosh HD:Users:etc:etc"
          set imageSet to get every file of folder sourceFolder
          end tell
                                set currentImg to (item i of imageSet) as string # coerce Finder style path to string
                                           activate
                                           open alias currentImg # for Photoshop, need to coerce it back to alias!
                                           #(rest of the code to adjust the images)
                                end tell
                     end repeat
          end tell
          Hth,
          greenrookie
          • 2. Re: Processing a folder of images with Applescript
            marty_76 Level 1
            greenrookie, you're a champion!
            The script just processed the folder of images- stoked
            The coercions and POSIX path changes you suggested worked perfectly
            Thanks again for your help
