3 Replies Latest reply on Nov 29, 2016 1:34 AM by Nanaky
    My license key is damaged
    tangberg
      I cannot open my purchased documents, getting an error message that my license key is damaged.
      I tried to erase my authorizations, but keep getting the message "Unable to Erase Authorization. Please try after som time".
      Can you please help?
        • 1. Re: My license key is damaged
          Nanaky Level 5
          If you get a error that license key damage it is a problem with the eBook itself. Try to download with a other internet browser. If not help you should contact the reseller of the eBook to check the file itself.
          To remove the authoirze used this:
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          • 2. Re: My license key is damaged
            madhusudanr94891469
            Thanks somuch for these tips. I could resolve the issue on my laptop.
            • 3. Re: My license key is damaged
              Nanaky Level 5
              That is fine.
