1 Reply Latest reply on Apr 4, 2016 11:43 PM by Nanaky
    Authorize Multiple Devices?
    mitchw58163835
      I authorized a first computer Adobe Digital Editions with and Adobe ID. But I cannot seem to authorize a second netbook computer ADE with an Adobe ID in order to transfer books from 2nd device to an ebook reader? How do you authorize multiple devices. You are supposed to be able to do 6. I keep getting error message Cannot authorize with the same ID as used to authorize another device?
      Thx.
        • 1. Re: Authorize Multiple Devices?
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
