• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
java.math.BigDecimal cannot be cast to java.lang.String
New Here ,
Apr 05, 2016 Apr 05, 2016
this sentence below is working fine on Coldfusion 11 and previous version, but it throws exceptions when the application is deployed on Coldfusion 2016
Could anyone give some advice on this issue?
<cfset SubjectText = Replace(#SubjectText#,"%Request.RequestID%",#Request.RequestID#,"All")>
the value of #Request.RequestID# is a number
Views
4.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
Can you give exact examples of what you are using for each variable.
I tried this and dont get any issues with it. - See Example http://trycf.com/gist/610a1e84aee0c490f4a2208296f890ee/acf2016?theme=monokai
Votes
Translate
Translate
Report
Report
New Here ,
Apr 06, 2016 Apr 06, 2016
yes it works in CF 11 and previous versions but  not working in CF 12
Votes
Translate
Translate
Report
Report
New Here ,
firstly i get the result from db:
<cfquery name="Request" DATASOURCE="WES" >
SELECT *
FROM REQUEST
WHERE RequestID = #RequestID#
</cfquery>
then do the replace of some text template
Votes
Translate
Translate
Report
Report
Advocate ,
What are the actual values though? What does SubjectText and RequestID represent?
If you replace these with the actual values does the same thing happen?
Votes
Translate
Translate
Report
Report
LEGEND ,
The first thing that I noticed (and this may or may not be part of the issue) is that you are naming the query object using a reserved word: request (as in the request scope.)
<cfset SubjectText = replace(SubjectText,"%Request.RequestID%",Request.RequestID,"all") />
Are you only trying to take an ID number surrounded by percent signs and remove the percent signs?
EDIT:  Seems to me that if you're just trying to remove the percent signs, then nested inside the percent signs should be hashmarks because the variable is contained within string demarcation.
<cfset SubjectText = replace(SubjectText,"%#Request.RequestID#%",Request.RequestID,"all") />
^_^
Votes
Translate
Translate
Report
Report
Guide ,
You shouldn't need the pound signs (#) around the variable Request.RequestID, although it appears to work even with them.
Votes
Translate
Translate
Report
Report
New Here ,
i removed the pound , but still get the same error
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 25, 2016 Apr 25, 2016
Definitely looks like I bug. I ran into the same issue. Like the error says, CF is failing to convert a BigDecimal to a string in order to use it in the replace function. This should work for you.
<cfset SubjectText = Replace(SubjectText,"%Request.RequestID%",javaCast('String',Request.RequestID),"All")>
For reference, here is an example that fails. In my case, the real value for the theBigDecimal was being generated by selecting an integer column from a simple query against Oracle. As you can see below, the javacast from bigdecimal to string works, but whatever it is doing in the replace function fails. I'll see if I can find were to file the bug.
<cfscript>
theBigDecimal = javaCast("bigdecimal", 123456);
theBigDecimalasString = javaCast("String", theBigDecimal);
newString = replace('This is my text with documentID in it','documentID',theBigDecimalasString);
writeDump('This Works: ' & newString);
writeDump('This Fails:');
newString = replace('This is my text with documentID in it','documentID',theBigDecimal);
</cfscript>
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
added to bug base
Bug 4144890
Votes
Translate
Translate
Report
Report
Resources
Documentation
