6 Replies Latest reply on Apr 13, 2016 8:04 AM by CarlosCanto
    How do I Change Swatch Names in Illustrator CC 2015?
    paragontony Level 1
      First, I know nothing about scripting or writing code.  That being stated, I am trying to use a script to change the swatch names in a PDF file in Illustrator CC 2015 for the PC.  Below is what I have cobbled together.  When the script hits the doc.swatches line I receive a "i is undefined."  I also changed the name of the swatches for the privacy purposes.  Thank you.
      var docs = File.openDialog("Select Files to Open", "*.pdf", true);
      var idx = 0;
      for (idx = 0; idx < docs.length; ++idx) {
          var doc = app.open(docs[idx]);
          var myCounter = 0;
          for (myCounter = 0; myCounter < doc.layers.length; myCounter++) {
              doc.layers[myCounter].locked = false;
              doc.swatches[i].name = doc.swatches[i].name.split('SwatchA').join('AlphaSwatch');
              doc.swatches[i].name = doc.swatches[i].name.split('SwatchB').join('BetaSwatch');
        • 1. Re: How do I Change Swatch Names in Illustrator CC 2015?
          Silly-V Adobe Community Professional
          To make this code work, you must understand how the javascript variables and loops work.
          Use this example to get a sense of what the "i" is and why it is not working properly in your snippet.
          http://www.w3schools.com/js/tryit.asp?filename=tryjs_loop_for
          • 2. Re: How do I Change Swatch Names in Illustrator CC 2015?
            paragontony Level 1
            I was able to get further with the script, but it's only changing one of the swatches.  Thoughts?  Thanks in advance.
            var idx = 0;
                var myCounter = 0;
                    doc.swatches[idx].name = doc.swatches[idx].name.split('swatch a').join('alpha swatch');
                    doc.swatches[idx].name = doc.swatches[idx].name.split('swatch b').join('beta swatch');
            • 3. Re: How do I Change Swatch Names in Illustrator CC 2015?
              paragontony Level 1
              Ok, I was able to get this script to run correctly, but it only changes one of the swatch names.  What am I missing?  Again, I changed the swatch names for privacy.
              var i = 0;
              for (i = 0; i < docs.length; ++i)
                  var doc = app.open(docs[i]);
                  var myCounter = 0;
                  for (myCounter = 0; myCounter < doc.swatches.length; myCounter++) {
                      doc.swatches[myCounter].locked = false;
                      doc.swatches[i].name = doc.swatches[i].name.split('Swatch A').join('Swatch Alpha');  //this name changes
                      doc.swatches[i].name = doc.swatches[i].name.split('Swatch B').join('Swatch Beta');   //this name doesn't
              • 4. Re: How do I Change Swatch Names in Illustrator CC 2015?
                CarlosCanto Adobe Community Professional & MVP
                try changing this
                to this
                doc.swatches[myCounter].name = doc.swatches[myCounter].name.split('Swatch A').join('Swatch Alpha');
                • 5. Re: How do I Change Swatch Names in Illustrator CC 2015?
                  paragontony Level 1
                  Thank you for your quick response and your patience.  When I made the changes I encountered a "MyCounter is undefined" when the script reaches the changed line.
                  • 6. Re: How do I Change Swatch Names in Illustrator CC 2015?
                    try this, the mechanics should work,
                    var doc = app.activeDocument;
                    for (var i = 0; i < documents.length; i++) {
                        //var doc = app.open(docs[i]);
                        //var myCounter = 0;
                        for (var myCounter = 0; myCounter < doc.swatches.length; myCounter++) {
                            doc.swatches[myCounter].name = doc.swatches[myCounter].name.split('Swatch A').join('Swatch Alpha');  //this name changes
                            //doc.swatches[i].name = doc.swatches[i].name.split('Swatch B').join('Swatch Beta');   //this name doesn't
