3 Replies Latest reply on Apr 5, 2016 10:50 AM by Laubender
    Add Metadata to JPG export pages?
    cathykka Level 1
      I have a script that exports the pages of an indesign file to a jpg.
      Is it possible to add metadata on jpg export?
      I have another script that will add meta to the whole doc, but I would like to add meta on a page by page basis during export.
      with (myDoc.metadataPreferences){
          author = "Me";
          documentTitle = docTitleText;
          keywords = docKeywords;
          description = docDescripText;
          copyrightNotice = "2005-2016 ©etc";
          copyrightInfoURL = "xx";
          copyrightStatus = CopyrightStatus.yes;
      main ();
      function main() {
          var curDoc = app.activeDocument;
          var docPath = curDoc.filePath;
          // create a folder
          var theFolder = new Folder(docPath + "/" + curDoc.name.replace(/\.indd$/,"") );
          if (!theFolder.exists) {
              theFolder.create();
      var curPage = app.activeWindow.activePage; // Find the active page.
      var docTitleText="";
      var docDescripText="";
      var docKeywords = [];
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.findWhat = '.+';
      found = app.activeDocument.findGrep (true);
      for (j = found.length-1; j >=0 ; j--)
          var foundText = found[j].contents;
          //You can define multiple Paragraph style for Document Title us else if
          if(found[j].texts[0].appliedParagraphStyle.name=="meta-title")
              docTitleText=found[j].contents;
          //You can define multiple Paragraph style for Document Description
          else if(found[j].texts[0].appliedParagraphStyle.name=="meta-description")
              docDescripText=found[j].contents;
          else if(found[j].texts[0].appliedParagraphStyle.name=="meta-key")
              docKeywords= found[j].contents.split(",");
      var filename= docTitleText.replace( /\s+$/ , "" ).replace( /\s+/g , "-" ).toLowerCase().replace(/\+/, '').replace(/\&-/, '').replace(/,/g, '').replace(/:/g, '').replace(/--/g, '-').replace(/\?/g, '').replace(/\./g, '');
      var myFilePath= theFolder + "/" + curDoc.name.replace(/\.indd$/,"")  + "-" + filename + ".jpg";
      var myFile = File( myFilePath );
              app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.HIGH; // low medium high maximum
              app.jpegExportPreferences.jpegRenderingStyle = JPEGOptionsFormat.BASELINE_ENCODING;
              app.jpegExportPreferences.jpegColorSpace = JpegColorSpaceEnum.RGB;
              app.jpegExportPreferences. exportResolution = 72;
              app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.EXPORT_RANGE;
              pageString = curPage.name;
          curDoc.exportFile(ExportFormat.jpg, myFile, false );
