0 Replies Latest reply on Apr 5, 2016 11:08 AM by Steve Sommers
    DateTime through local2utc through JSON bug
    Steve Sommers Level 4
      I believe I found a bug in CF11 with DateTime comparisons when dealing with UTC converted values going through serializeJSON then deserializeJSON. I did modify the code to not include the local2utc conversion and that seemed to produce correct results. Can someone please confirm:
      <cfscript>
        variables.dttm = createDateTime(2016,04,03,17,53,0);
        variables.dttmutc = dateConvert('local2utc',variables.dttm);
        variables.base = {};
        variables.base.dttmutc_min = dateConvert('local2utc',dateAdd('h',-1,variables.dttm));
        variables.base.dttmutc_max = dateConvert('local2utc',dateAdd('n',1,variables.dttm));
        variables.viajson = deserializeJSON(serializeJSON(variables.base));
        variables.viajson.dttmutc_min = parseDateTime(variables.viajson.dttmutc_min);  // to me this parsing should not be required
        variables.viajson.dttmutc_max = parseDateTime(variables.viajson.dttmutc_max);  // same
      </cfscript>
      <cfoutput>
        <h1>base</h1>
        dttm = #variables.dttm#<br />
        dttmutc = #variables.dttmutc#<br />
        dttmutc_min = #variables.base.dttmutc_min#<br />
        dttmutc_max = #variables.base.dttmutc_max#<br />
        <br />
        dttmutc GT dttmutc_min = #variables.dttmutc GT variables.base.dttmutc_min#<br />
        dttmutc LT dttmutc_max = #variables.dttmutc LT variables.base.dttmutc_max#<br />
        <h1>via json</h1>
        dttmutc_min = #variables.viajson.dttmutc_min#<br />
        dttmutc_max = #variables.viajson.dttmutc_max#<br />
        <br />
        dttmutc GT dttmutc_min = #variables.dttmutc GT variables.viajson.dttmutc_min# (should be YES)<br />  // this is the failing comparison
        dttmutc LT dttmutc_max = #variables.dttmutc LT variables.viajson.dttmutc_max#<br />
      </cfoutput>
      My results are as follows:
      base
      dttm = {ts '2016-04-03 17:53:00'}
      dttmutc = {ts '2016-04-04 00:53:00'}
      dttmutc_min = {ts '2016-04-03 23:53:00'}
      dttmutc_max = {ts '2016-04-04 00:54:00'}
      dttmutc GT dttmutc_min = YES
      dttmutc LT dttmutc_max = YES
      via json
      dttmutc GT dttmutc_min = NO (should be YES)
      BTW, I'm not sure if it matters but my time zone is Pacific Daylight Time (PDT).
