5 Replies Latest reply on Apr 6, 2016 12:45 AM by BEGINNER_X
    Find & Replace as per page only (not for Document)
    BEGINNER_X Level 3
      Hi All,
      Customer provided the Word document in Table format (around 200 Pages).
      Need to find Column1 text and change Column2 text in the Indesign Document.
      So, I flow the word file in Pasteboard and need to do the changes in the Indesign document as per PAGE.
      FYI, trying sample reference Indesign file Screenshots,
      Script got from Forum, but it works for Whole document not for Page Sequence.(clarify in 16th line)
      the_table = app.selection[0].tables[0];
      app.findChangeTextOptions = null;
      with (app.findChangeTextOptions)
       caseSensitive = true;
       wholeWord = true;
      app.findTextPreferences = null;
      app.changeTextPreferences = null;
      for (row=0; row<the_table.rows.length; row++)
         if (the_table.rows[row].cells[0].contents == '')
           continue;
         app.findTextPreferences.findWhat = the_table.rows[row].cells[0].contents;
         app.changeTextPreferences.changeTo = the_table.rows[row].cells[1].contents;
         app.activeDocument.changeText();
      Thanks in Advance
      Siraj
        • 1. Re: Find & Replace as per page only (not for Document)
          b91823603 Level 3
          Hi
          You could try this,
          var myTable = app.selection[0].tables[0];
          var myRows = myTable.rows;
          for (i=0; i<myRows.length; i++)
              myRows[i].cells[0].contents = myRows[i].cells[1].contents;
          • 2. Re: Find & Replace as per page only (not for Document)
            BEGINNER_X Level 3
            Thank you for quick response...
            But, I need changes only in Particular page wise (not for document).
            Please see the PasteBoard Text in Screenshot.
            • 3. Re: Find & Replace as per page only (not for Document)
              b91823603 Level 3
              It will replace contents based on the text frame selection only. It will not change all document text frames.
              • 4. Re: Find & Replace as per page only (not for Document)
                b91823603 Level 3
                You could use your code also, You need to change the 16th line as below for replace contents only in selected table,
                the_table.changeText();
                • 5. Re: Find & Replace as per page only (not for Document)
                  BEGINNER_X Level 3
                  Thank You Dillibabu...
                  I write the below script with the help of existing script. Working Fine in testing file.
                  app.findChangeTextOptions.wholeWord = false;
                  app.findChangeTextOptions.caseSensitive = false;
                  app.findTextPreferences = app.changeTextPreferences =null;
                    if (the_table.rows[row].cells[0].contents.match(/PAGE \d+/i) != null)
                        var myPage_Text = the_table.rows[row].cells[0].contents;
                        //alert("myPage_Text: " + myPage_Text)
                        var myPage = String(myPage_Text).replace("page ", "");
                        alert(myPage)
                    app.documents[0].pageItems.everyItem().locked = true;
                    //app.documents[0].pages.itemByRange(2,2).pageItems.everyItem().locked = false;
                    app.documents[0].pages.item(myPage).pageItems.everyItem().locked = false;
                     //alert("To Find: " + the_table.rows[row].cells[0].contents)
                     //alert("To Change: " + the_table.rows[row].cells[1].contents)
                    app.documents[0].pageItems.everyItem().locked = false;
                  Siraj
