4 Replies Latest reply on Apr 7, 2016 1:56 AM by runew73276507
    Modify excisting script to check for missing or out of date links AND missing fonts
    runew73276507
      OBS: InDesign CS3 script:
      I have this script:
      if (app.documents.length != 0){
         var myFrames = app.activeDocument.textFrames;
         var thePageNames = new Array();
         for (var j = 0 ; j <= (myFrames.length - 1); j++) {
           if(myFrames[j].overflows == true){
             try {
               thePageName = myFrames[j].parent.documentOffset;
             } catch (e) {
               continue; // must be on Pasteboard so ignore
             thePageNames[thePageName] = 1
         if (thePageNames.length == 0) {
         } else{
             var s = "";
           for (i in thePageNames) {
             s = s + app.documents[0].pages[Number(i) - 1].name + ", ";
           s = s.substring(0,s.length - 2);
           if(!confirm("Overset text on page - continue?"))
           exit();
      With the same princip and funtion I would like it to also check for:
      1. Missing or Out of date links
      2. Missing fonts
      Can anyone help me rewrite this? I have tried with this for the links part but nothing happens when I run the script:
         var myLinks = app.activeDocument.links;
         for (var j = 0 ; j <= (myLinks.length - 1); j++) {
           if(myLinks[j].status == LinkStatus.LINK_MISSING || myLinks[i].status == LinkStatus.LINK_OUT_OF_DATE == true){
             try {
               thePageName = myLinks[j].parent.documentOffset;
             } catch (e) {
         } else{
             var s = "";
           if(!confirm("Missing or not updated links in document - continue?"))
           exit();
        • 1. Re: Modify excisting script to check for missing or out of date links AND missing fonts
          biozaichenko Level 1
          I think this should get you started.
          if (app.documents.length != 0) {
             for (var j = 0 ; j < myLinks.length; j++) {
               if(myLinks[j].status == LinkStatus.LINK_MISSING || myLinks[i].status == LinkStatus.LINK_OUT_OF_DATE){
                 if (myLinks[j].parent.parentPage.isValid) {
                    thePageNames.push (myLinks[j].parent.parentPage.documentOffset);
                 } else {
                   thePageNames.push ("Pasteboard");
             if (thePageNames.length > 0) {
               alert (thePageNames.length + "missing or not updated links in document."))
          Michael
          • 2. Re: Modify excisting script to check for missing or out of date links AND missing fonts
            b91823603 Level 3
            I modified 13th line in your code it will work and then added code for font missing also. Try this
                var MY_DOC = app.activeDocument;
               var myLinks = MY_DOC.links;
                   try
                        thePageName = myLinks[j].parent.parentPage.documentOffset;
                   catch (e)
                if (thePageNames.length != 0)
                    var s = "";
                        exit();
                    if(fun_FontMissing)
                         if(!confirm("Font missing in document - continue?"))
                            exit();
            function fun_FontMissing()
                var isFontMis=false;
                try{
                    for(var i=0;i<MY_DOC.fonts.count();i++){
                        if(MY_DOC.fonts[i].status==1718832705 || MY_DOC.fonts[i].status == 1718834037 || MY_DOC.fonts[i].status == 1718830689){
                            isFontMis=true;
                catch(ex){
                    alert(ex);
                    exit();
                return isFontMis;
            • 3. Re: Modify excisting script to check for missing or out of date links AND missing fonts
              runew73276507 Level 1
              It does not work in InDesign CS3
              It works fine in InDesign CC 2015 - but I need this for CS3 - can you assist me once more?
              • 4. Re: Modify excisting script to check for missing or out of date links AND missing fonts
                And by the way - If you press "YES" to continue for the missing or out of date link part it also alert for a missing font even thoe there is no fonts used in the document?
