0 Replies Latest reply on Apr 6, 2016 7:25 AM by RosettaBooks
    Export tags across all of a book's documents won't synchronize unless the documents are manually opened
    RosettaBooks Level 1
      Possible bug/feature request:
      I have a book (.indb) that's split up into one INDD document per chapter. I have all the synchronization options turned on, and when I select all documents in the book and synchronize, it updates paragraph styles and the usual suspects--but it doesn't update the export tags from the style source document to the other documents.
      As a workaround, I've discovered that I can manually open each document in the book and then, once they're all open, synchronize, and then the export tags update--so that's nice.
      But I'd expect that the export tags should synchronize the same way the paragraph styles and other options do, whether I've manually opened all the book's document or not, right?
