3 Replies Latest reply on Apr 7, 2016 11:02 AM by charlespearce
    Can't import camera raw files
    charlespearce
      In AE CC, I can't import camera raw files in either native .nef format or .dng as image sequence. I get the error below. I've tried opening the sequence in Adobe Camera Raw and exporting as .dng, but that doesn't help.Screen Shot 2016-04-06 at 9.20.36 PM.png
      Any help would be appreciated.
        • 1. Re: Can't import camera raw files
          Make sure that AE, Camera Raw, Photoshop and Lightroom if you have it are up to date. If that doesn't work use Lightroom or Bridge to export a tiff sequence. If you are taking high rez raw files shot as time lapse then I highly suggest that you size them to an appropriate frame size for video before you import the sequence.
          • 2. Re: Can't import camera raw files
            charlespearce Level 1
            Everything is up-to-date, which may be the problem. I read on a forum that Adobe Camera Raw 9.5 doesn't work with AE, but that 9.1 does. Now I'm trying to figure out how to get back to an earlier version.
            I've imported raw files into AE before and I prefer that over converting to tiff or jpg because I have more control over the final resolution and can further refine color, etc. in AE, coming from Lightroom. Sizing to the appropriate frame size before going into AE isn't the ideal solution because it is too limiting.
            • 3. Re: Can't import camera raw files
              That was the issue. After downgrading to ACR 9.1, the files opened successfully in AE. As ACR 9.5 has been around for awhile, it seems that Adobe would have fixed this bug by now.
