1 Reply Latest reply on Apr 7, 2016 12:05 AM by Migintosh
    I can't see the graphics that I've imported into my Id document.
    ammam75221483
      The eyeball is on, the layer isn't locked and the links appear in the links panel - why can't I see them? Every time I try and place a new graphic it also won't show in the doc. HELP!!
      I've had a look at the links panel and it says that they are all scaled at 0% (although I'm not sure why). When I try to adjust the width and height in the toolbar it gives me an error message.
      Any clue?
        • 1. Re: I can't see the graphics that I've imported into my Id document.
          Migintosh Level 4
          If you drag the cursor while you click, it will scale the image to the size of the frame that will be created. The smaller you drag the cursor, the smaller it will be. If you are trying to just click and not drag, but you inadvertently drag a tiny bit, you could end up with what you describe. If so, it could be a bad mouse or a too-sensitive setting in your mouse controls. Try dragging out a larger frame and see if that helps.
