2 Replies Latest reply on Apr 7, 2016 4:49 AM by ritae6568421
    Lightroom menu bug - Edit In and PhotoMerge options not available.
    ritae6568421 Level 1
      In Lightroom - "Edit In" requires two images to be selected to make menu options available should only be one.  "Photomerge" menu options not available with one or 2 images selected.  This is a software bug.  Running windows 7.  Have uninstalled and re-installed both Lightroom and Photoshop but it has not fixed the problem.   Please advise.  Not sure how to report this to Adobe.
        • 1. Re: Lightroom menu bug - Edit In and PhotoMerge options not available.
          Just Shoot Me Adobe Community Professional
          I think, I know, this problem is specific to your computer.
          I also use Win 7 and don't have this problem.
          I suspect the first image you are selecting isn't really available, Missing, in some way.
          For both HDR and Panorama to become available all you need is 2 images selected. Try trashing the preferences file which wouldn't be replaced with a reinstall as it is located in your Username folder.
          • 2. Re: Lightroom menu bug - Edit In and PhotoMerge options not available.
            You are correct.  The issue appeared to be with one image that I had edited and then made a virtual copy so that I could edit in Nik.  I have synchronised that folder of images and my menus have returned.  However, I have lost the lightroom edits to other images that I made after the virtual copy of the earlier image.  They were just quick edits so they are easy to re-do.  I am reluctant to make a virtual copy again in case this happens again, although I might try later in the weekend to see if that was the actual cause of the problem.
            Thank you for your assistance.
