2 Replies Latest reply on Apr 7, 2016 7:21 AM by Ivo Marinovic
    How to animate numbers between two values for eg binary digits?
    rosenbax
      I have this Numbers:
      101 0110 11100110101101110
      I want to switch them -  the 0 into 1 and the 1 into 0. Subsequently the numbers should pass over into a word.
      It is only possible to switch the numbers into digits from 2-9.
      This Animation should be no longer than 4-6 seonds.
      Do you have an Idea?
      Greetings
      rosenbax
        • 1. Re: How to animate numbers between two values for eg binary digits?
          You can do that with the text animators in AE if you can live with random numbers. No need for a complicated expression.
          1. Type a line of zeros
          2. Add a Character Offset animator
          3. Add Wiggly Selector
          4. Set character offset to 1
          5. Change the minimum amount to 0%
          6. Set the wiggles per second
          You'll have to spin things down to get there.
          To convert the binary code to a word I'd add another text animator for opacity and then animate the range selector to turn off one letter at a time.
          Add a new text layer with our word and use an opacity animator to reveal one letter at a time and then just line them up
          This will work best with a monospaced font.
          If you need sequential binary digits you'll have to use an expression and then add the opacity animator to make the transition to the word. Unfortunately I don't have that expression in my head but you can probably find a java script binary counter somewhere that can be turned into an expression fairly easily.
          • 2. Re: How to animate numbers between two values for eg binary digits?
            Ivo Marinovic Level 1
            Use solid than apply numbers effect on it! Try to play with it, I hope it helps!
