2 Replies Latest reply on Apr 8, 2016 7:05 AM by markh21414623
    How to check if a node exists in XML file?
    markh21414623
        I have been asked to programme a method for importing data from xml files into our Coldfusion 8 website, I am new to using XML.
      My method had been working however I encounted the following error:
      Element NETWORKORDER.SECONDARYADDRESS.CONTACTNAME is undefined in MYDOC.
      On investigation the node in the XML file was not present.
      Is there a method I can use to resolve this error by checking if a node exists in the xml file,  that works with my current code below?
      <!--- Read XML file --->
      <cffile action="read" file="D:\website\XML\#FileName#" variable="myxml">
      <cfset mydoc = XmlParse(myxml)>
      <!--- Extract Data from NDS XML File --->
      <cfset aPrimaryContactName=(#mydoc.NetworkOrder.PrimaryAddress.ContactName#)>
      <cfset aPrimaryContactNumber=(#mydoc.NetworkOrder.PrimaryAddress.ContactNumber#)>
      <cfset aPrimaryContactNumber= tostring(#mydoc.NetworkOrder.PrimaryAddress.ContactNumber#)>
      <cfset aPrimaryContactAddressLine1=(#mydoc.NetworkOrder.PrimaryAddress.line1#)>
      <cfset aPrimaryContactAddressLine2=(#mydoc.NetworkOrder.PrimaryAddress.line2#)>
      <cfset aPrimaryContactAddressLine3=(#mydoc.NetworkOrder.PrimaryAddress.line3#)>
      <cfset aPrimaryContactAddressLine4=(#mydoc.NetworkOrder.PrimaryAddress.line4#)>
      <cfset aPrimaryContactAddressLine5=(#mydoc.NetworkOrder.PrimaryAddress.line5#)>
      <cfset aPrimaryContactCity=(#mydoc.NetworkOrder.PrimaryAddress.City#)>
      <cfset aPrimaryContactPostcode=(#mydoc.NetworkOrder.PrimaryAddress.PostalCode#)>
      <cfset aPrimaryContactCounty=(#mydoc.NetworkOrder.PrimaryAddress.CountrySubdivision#)>
      <cfset aPrimaryContactCountryCode=(#mydoc.NetworkOrder.PrimaryAddress.CountryCode#)>
      <cfset aPrimaryContactCountry=(#mydoc.NetworkOrder.SecondaryAddress.Country#)>
      <cfset aSecondaryContactName=(#mydoc.NetworkOrder.SecondaryAddress.ContactName#)>
      <cfset aSecondaryAttentionOfName=(#mydoc.NetworkOrder.SecondaryAddress.AttentionOfName#)>
      <cfset aSecondaryContactNumber=(#mydoc.NetworkOrder.SecondaryAddress.ContactNumber#)>
      <cfset aSecondaryContactAddressLine1=(#mydoc.NetworkOrder.SecondaryAddress.line1#)>
      <cfset aSecondaryContactAddressLine2=(#mydoc.NetworkOrder.SecondaryAddress.line2#)>
      <cfset aSecondaryContactAddressLine3=(#mydoc.NetworkOrder.SecondaryAddress.line3#)>
      <cfset aSecondaryContactAddressLine4=(#mydoc.NetworkOrder.SecondaryAddress.line4#)>
      <cfset aSecondaryContactAddressLine5=(#mydoc.NetworkOrder.SecondaryAddress.line5#)>
      <cfset aSecondaryContactCity=(#mydoc.NetworkOrder.SecondaryAddress.City#)>
      <cfset aSecondaryContactPostcode=(#mydoc.NetworkOrder.SecondaryAddress.PostalCode#)>
      <cfset aSecondaryContactCounty=(#mydoc.NetworkOrder.SecondaryAddress.CountrySubdivision#)>
      <cfset aSecondaryContactCountryCode=(#mydoc.NetworkOrder.SecondaryAddress.CountryCode#)>
      <cfset aSecondaryContactCountry=(#mydoc.NetworkOrder.SecondaryAddress.Country#)>
        • 1. Re: How to check if a node exists in XML file?
          Steve Sommers Level 4
          Since you already have the xml parsed into a document, the easiest is to use xmlSearch(). Take a look at the doc, it's pretty easy to use. Something as simple as:
              <cfset a = xmlSearch(mydoc,"//NetworkOrder/PrimaryAddress/ContactName" ) />
          To more complex like:
              <cfset a = xmlSearch(mydoc,"//*[local-name()='ContactName']" ) />
          And in either case:
              <cfif arrayLen(a)> <!--- something found ---> </cfif>
          Read the doc and google is your friend "coldfusion xmlsearch"
          • 2. Re: How to check if a node exists in XML file?
            markh21414623 Level 1
            Thank you Steve for pointing me in the right direction. Somtimes when you google for information you can't see the forest for the trees.
            Your simple method works perfectly.
