4 Replies Latest reply on Apr 7, 2016 7:38 AM by try67
    Assigning a unique ID for each annotation in JS
    kalabal Level 1
      Hi everyone,
      I made a JS code to export all the annotations in a .pdf file to a .csv file and it works fine. I also need to assign a unique ID number for each row similar to a database table but couldn't figure a way out.
      The issue is that if a user deletes an annotation, ID numbers of annotations after the deleted annotation will change if I use value of "i" in the "for" loop. Somehow I need to store the ID numbers in each annotation.
      Let's say I have 3 annotations in a .pdf file, and run the code below;
      this.syncAnnotScan();
      var annots = this.getAnnots()
      for ( var i= 0; i< annots.length; i++) {
          console.println(i+1);
          console.println("Type:"+annots[i].type);
          console.println("Text:"+annots[i].contents);
          console.println("-----");
      Results are ;
      1
      Type:Text
      Text:Comment-1
      2
      Type:Text
      Text:Comment-2
      3
      Type:Text
      Text:Comment-3
      If I delete the annotation-2, then the results will be;
      1
      Type:Text
      Text:Comment-1
      2
      Type:Text
      Text:Comment-3
      I'm trying to keep the ID number "3" for the comment-3 even if I delete the comment-2. Is there a simple way to do that? Any kind of help is appreciated.
      Regards.
