2 Replies Latest reply on Feb 18, 2009 12:13 PM by RoboHobo
    Project rename incomplete
    RoboHobo
      Hi -
      I am using RoboHelp 7. The project is RoboHelp Pro. I am using a custom window and skin.
      I renamed a Help project (named "Test") using File > Rename Project. Now when I generate WebHelp Pro output, the following generated files appear in the output folder with the old project name:
      Test.glo
      Test.hhc
      Test.hhk
      Test.htm
      Test.lng
      Test.ppf
      Test.stp
      Test.syn
      Test_csh.htm
      Test_hha.hhk
      Test_rhc.htm
      Things I have tried:
      - searching the project directory for any file named or containing the word Test or test. (None.)
      - manually updated all SSLs to reflect the new project name (they did not update with the rename action).
      - shut down and restart, reboot, etc., go home and come back the next day ;)
      - searched the registry for references to Test (getting desperate but treading carefully where I delete).
      With all of this, the problem is not any clearer.
      If I select File > View Primary Layout, the path in the browser address window for the default topic is:
      C:\...\!SSL!\WebHelp_Pro\Test.htm
      If I select File > View From Server, it does show the correct default topic and file name in the browser address window.
      Anyway, the question is, for someone smatter than I, from where could RoboHelp be picking up the old project name, and how might I fix it?
      Thanks!
