3 Replies Latest reply on May 2, 2016 12:24 PM by btempleton1982
    InvokeMenuAction on artwork on artboard
    christianbrugeron Level 1
      Hi folks
      I am trying to adjust the siez of my artboards to their content.
      If I invoke the menu commands by hand, it works.
      If I put these commands in my plug in, AI resets the artboard size just after execution!
      My code (some instructions may be redondant).
      for (int i = 0; i < size; i++) {
      string s = listPng[i]; // artboards names
      int idx = CherchePTparNom((char*)s.c_str()); // get the idx of the artboard
      // selectionner ce PT
      ASErr erreur = kNoErr;// pour le fichier log
      erreur = sAIArtboard->Init(prop);
      erreur = sAIArtboard->GetArtboardList(artboardList);
      erreur = sAIArtboard->GetArtboardProperties(artboardList, idx, prop);
      erreur = sAIArtboard->SetActive(artboardList, idx);
      erreur = sAIArtboard->Update(artboardList, idx, prop);
      // envoyer "tout selectionner du plan de travail" avant d'ajuster
      erreur = sAIMenu->InvokeMenuAction(selectALL);
      // envoyer la commande de match entre PT et contenu
      erreur = sAIMenu->InvokeMenuAction(fitArtboardToArtwork);
      Any help is welcome!!
      Christian
        • 1. Re: InvokeMenuAction on artwork on artboard
          LeoTaro Level 4
          brugeron wrote:
          Hi folks
          You are getting the artboard properties, then you call the menu action that changes the artboard properties and then you update the artboard using the properties before you called the menu action.
          Try this:
          • 2. Re: InvokeMenuAction on artwork on artboard
            no amelioration, but thanks
            No artboard seems affected, but the lastone during a few seconds; then AIresets the size of teh artboard.
            There is no feed=back onthe setactive command, also.
            cb
            • 3. Re: InvokeMenuAction on artwork on artboard
              btempleton1982 Level 2
              I would try using the ArtSet suite functions to find the actual bounds of the artwork, then GetArtboardProperties, change the properties to the bounds you found, and call Update. It looks like you're mashing together two different ways of doing the same thing.
              LeoTaro's solution looks like it should work, but I'm not too sure about the peculiarities of InvokeMenuAction. I'd recommend doing it using the Artboard suite functions.
