1 Reply Latest reply on Apr 8, 2016 8:53 PM by S Hopkins
    Create document based on intent options
    JulianFT
      Hi all,
      I'm trying to check whether a document has the intent option set to digital publishing, and if not, create a new one that has that option. I tried the script below, but that doesn't seem to work as intended. Any suggestions would be highly appreciated!
      Kind regards,
      Julian
      function createDocument(){
      try{
      // Check to see if a document is open; if not, create it under the catch
      var myDocument = app.activeDocument;
      var myDocumentPreset = app.documentPresets.add();
      myDocumentPreset.createPrimaryTextFrame = true;
      // Check to see if the open document is meant for digital publishing. If not, create a new one.
      if (myDocument.documentPreferences.intent != DocumentIntentOptions.DPS_INTENT){
      var myDocument = app.documents.add({documentPreset:myDocumentPreset});
      myDocument.documentPreferences.intent = DocumentIntentOptions.DPS_INTENT;
      alert(myDocument.documentPreferences.intent);
      catch(e){
        • 1. Re: Create document based on intent options
          S Hopkins Adobe Community Professional
          I don't see a problem with the exception that you are not calling the function.
          createDocument();
          function createDocument() {
             etc.
          I might suggest that you don't create the document preset until you need it, for example:
          checkDocument();
          function checkDocument() {
            try {
               if (myDocument.documentPreferences.intent != DocumentIntentOptions.DPS_INTENT) {
                  myDocument = newDocument();
          } catch (e) {
          function newDocument() {
              var myPreset = app.documentPresets.add();
              myPreset.createPrimaryTextFrame = true;
              var myDocument = app.documents.add({documentPreset:myPreset});
              return (myDocument)
