3 Replies Latest reply on Apr 13, 2016 9:39 PM by karth80472045
    svg to pdf
    karth80472045 Level 1
      i have 100 svg files in folder , in that svg files artboard size is 234,1mm and 171mm it should save as pdf in A4(297^210mm) format same as that of svg file name , and in some svg file the file is twice of the artboard 468.2mm and 342mm in that case it should save as A4 pdf with same file name for artboard size 234.1mm and 171mm with -1 for first page and for second page -2 , please anybody can you able to write script for this ?
        • 1. Re: svg to pdf
          Monika Gause Adobe Community Professional & MVP
          Please describe step by step what exactly you're doing, what exactly you expect and what exactly goes wrong.
          You might also make a break in-between to structure your thoughts. Thank you.
          • 2. Re: svg to pdf
            first we will open svg file , in that artboard size is 234.1mm and 171mm for this size we will save as pdf in a4 format same as that svg file name, sometimes artboard size is 468.2mm and 171mm (horizontally artboard extension) for this size we will select 234.1mm and 171mm and then we will as pdf in A4 format same as that svg file name with -1  then we will next content (image) in 234.1mm and 171mm and save as pdf same save as that svg file name with -2 .pdf
            like this vertical page extension (234.1 mm & 342mm ) for this also we select first 234.1mm and 171mm and then we will as pdf in A4 format same as that svg file name with -1  then we will next content (image) in 234.1mm and 171mm and save as pdf same save as that svg file name with -2 .pdf, this is how we will do can anybody able to write sript.
            • 3. Re: svg to pdf
              please anybody help me
