• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Does RH mess with your custom HTML?
Participant ,
Feb 25, 2009 Feb 25, 2009
I posted this feature request:
quote:
"Leave-this-alone" signal to RH: Please implement some kind of code or comment or other signal that tells RH, "Leave this code alone. Don't mess with this code." That way, users can implement their own special solutions when needed, without RH messing it up as soon as you switch to HTML view.
Adobe expressed interest in this and asked me for examples of when RH messes up user code. But I have only one example:
quote:
I inserted a placeholder in the code of a drop-down. But when I switch back, and view the drop-down from the Design tab, RH deletes it.
If you have other examples, post them here and I'll give the Adobe rep a link to this thread or email the examples to him.
Regards,
Eileen
Views
583
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advisor ,
They've already fulfilled my code request in RH8, which was to carry over ZOOM search "kill" tags (<!--ZOOMSTOP--> and <!--ZOOMRESTART-->) from source to output. Older versions would simply drop them from the code during the generation process.
I use these tags to keep H1 and navigation content from appearing in the "page's meta description" and therefore had to index against my source and manually update the Zoom files into the output folder. (A little thing, I know, but any manual tweaking invites possible errors...)
Many thanks, Adobe-niks, and keep up the terrific work! I can't wait till we finally get the update for RH 8 (from X502, would you believe) approved by Finance!.
Leon
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi all
I've seen it where folks want to associate more than a single style sheet (.CSS file) and personally I've seen it happen where I'll add my own META tag only to have RoboHelp ever so politely discard it.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Participant ,
Can I just send them Rick's TipsNTrix.chm?
Votes
Translate
Translate
Report
Report
New Here ,
Feb 27, 2009 Feb 27, 2009
LATEST
I had a similar problem when i specify it to use a Windows media player active x control to play a .avi file, RH would replace my html code to use the quicktime active x control instead... took me hours to figure out that this was going on. Had to use javascript to get around this - luckly RH wasn't smart enough to parse that and modify it 🙂
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
