3 Replies Latest reply on Mar 8, 2009 9:00 AM by Necromanthus
    Help me
    vova1001
      In 3D Max Is available
      Running Scripts
      You can run a script from within other scripts using the fileIn() method:
      fileIn <filename_string> [ quiet:<boolean> ]
      where <filename_string> is a string literal or an expression that evaluates to a string, and specifies the name of the script file whose content is executed. The script file content is executed one expression at a time, and halts processing if an error is encountered at any point. By default, the file is not listed as it is loaded; use quiet:false to get a running listing to the Listener.
      EXAMPLE USAGES ARE:
      fileIn "my_script.ms"
      Is available Macromedia Director ????
