2 Replies Latest reply on Feb 19, 2009 6:17 AM by wt.ustc
    VDividedBox not restoring the divider position after switching states
    wt.ustc
      I've got two panels in a VDividedBox: a top panel and a bottom panel. Then I create a state, which will replace the top panel with a third panel. When switching back to the base state, however, the top panel doesn't occupy the original divided space, it is pushed all the way to the top and is obviously minimized. Also, what I noticed is that, if I change the divider position before switching the states, everything looks fine. Please see code attached and help me with this hopefully quick issue. Thank you.
