2 Replies Latest reply on Apr 14, 2016 2:21 PM by streshi
    Using an animation as a preloader for a website
    streshi
      Hello!
      I have an animation that I would like to use as a preloader or an intro for a website.
      I'd like to run the animation and then for it to banish and display the website, the idea is to load the website behind while animation is playing.
      Is there a way for doing this?
      I'll really really appreciate your help!
      Thanks!
        • 1. Re: Using an animation as a preloader for a website
          ddhayles Level 3
          You can try putting your website in a div and then setting css value of that div to hidden. When you are ready for it to be shown you can get set the visibility to true:
          visibility: visible|hidden;
          Alternatively first load your EA project html file then when that finishes set off the following code:
          window.location="http://www.adobe.com";
          • 2. Re: Using an animation as a preloader for a website
            streshi Level 1
            Thank you very much!
            I've tryed what you said and it works great!
            Except for a little detail... Adobe Edge Animate script is now blocking my web scripts, after the animation runs, the web is displayed but all scripts are frozen.
            I have my animation items (with scripts) inside a div, and the web elements in another div.
            Im not much of an expert with javascript but I believe something in edge's code keeps the other scripts from running
