2 Replies Latest reply on Apr 11, 2016 11:26 AM by testr3456456546
    Save the file with the same name
    testr3456456546 Level 1
      How to change the script to save the file with the same name ?
      //SaveforWebSP.jsx
      //Save a fixed width image with a size constraint in its original folder
      var docRef = activeDocument;
      var outputFolder = docRef.path;
      NamesaveRef = new File( outputFolder + "/reference.jpg" );
      var NewfileRef = new File( NamesaveRef )
      // quality/size constraints
      var w = 1920; // new file width
      var MaxSz =  361440; // max. 360Kb
      var Qlt = 100; // initial quality 100
      var x = 1; // decreasing step
      // resize the image to the right width
      docRef.resizeImage(UnitValue(w,"px"),null,100,ResampleMethod.BICUBICSHARPER);
      // Perform the first SaveForWeb Operation
      ExpWeb(NewfileRef, Qlt);
      // Keep trying to save the file with max. Qlt, but under MaxSz
      while (NewfileRef.length > MaxSz)
      Qlt = Qlt - x;
      NewfileRef = new File( NewfileRef );
      NewfileRef.remove();
      ExpWeb(NewfileRef, Qlt);  // Perform a new SaveForWeb Operation, with slightly lower Qlt
      if (Qlt <= 40) {
      alert("The file can't be saved with the desired size AND quality.");
      break  // break the loop whenever the quality is as low as 50 (this shouldn't need to happen)
      var FileSz = NewfileRef.length/1024;
      FileSz = Math.round(FileSz);
      // close the original file without saving
      activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      // SaveForWeb Export, with the desired constraints and parameters
      function ExpWeb(FileNm, Qlt)
      var options = new ExportOptionsSaveForWeb();
      options.quality = Qlt;   // Start with highest quality (biggest file).
      options.format = SaveDocumentType.JPEG;   // Save Format for the file
      docRef.exportDocument(File(FileNm), ExportType.SAVEFORWEB, options);
