5 Replies Latest reply on May 2, 2006 3:56 PM by goldfingeratb
    Annoyingly simple
    goldfingeratb Level 1
      Hey,
      This is such an elementary problem which I am sure everyone one of you could solve, but at the moment I cannot do it and its giving me a headache. Basically I have a button with an instance name of goPlay_btn and I want it to go to Scene 8 on release. I have tried all the usual methods but I keep getting this error:
      Statement must appear within on handler
      This is the code I have put in:
      goPlay_btn.onRelease = function (){
      gotoAndPlay("Scene 8", 1);
      What is going wrong?!
      Any help appreciated!
      Regards,
      Adam Justice
        • 1. Re: Annoyingly simple
          Level 7
          Looks like you are trying to put this code on a button or some other symbol.
          Put it on the timeline.
          Dan Mode
          *Must Read* http://www.smithmediafusion.com/blog
          *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
          "goldfingeratb" <webforumsuser@macromedia.com> wrote in message
          news:e38k40$e31$1@forums.macromedia.com...
          > Hey,
          > could
          > Basically
          > this
          > error:
          > Regards,
          > Adam Justice
          • 2. Re: Annoyingly simple
            boxdoctor Level 1
            Hi Adam.....funny my last name is Justice as well. I take it this code is appearing on your main timeline and not inside the timeline of another clip or on the button itself.
            That being said did you try:
            goPlay_btn.onRelease = function() {
            gotoAndPlay("Scene 8");
            also try:
            gotoAndPlay(8);
            Just to make sure you don't have a frame name issue.
            Let me know.
            • 3. Re: Annoyingly simple
              Bishop[Neo] Level 1
              You have to specify the name of the scene, not Scene 8 unless that is the actually name. For instance if the 3rd scene is named scene_number_three you would use
              gotoAndPlay("scene_number_three") not gotoAndPlay("Scene 3");
              You don't *need* a frame number as it will assume frame 1, unless you don't want frame 1. Becareful you aren't accidentally refering to a frame.
              BTW, gotoAndPlay(8); will play from frame 8 of the current movie and timeline
              • 4. Re: Annoyingly simple
                Bishop[Neo] Level 1
                Also, where did you put the AS? Best bet would be on the button itself, then you only need:
                on (release) {
                gotoAndPlay("scene_name");
                • 5. Re: Annoyingly simple
                  Hey thanks everyone, I ended up just putting the code in the timeline, and then it worked.
                  Thanks!
