3 Replies Latest reply on Apr 12, 2016 6:40 AM by winterm
    break apart
    muratz07 Level 1
      Hello to everyone.
      In corel draw, there is an option named "break apart". With it, you can seperate a paragraph into apart sentences. Also you can do it on sentences or words. At last you can have seperated letters. This tool is great in use. Especially while designing typographic  - artistic stuff.
      It was also not in Illustrator. But i found an indirect way to make it in Illustrator and shared it with community. ( flatten transparency )
      Do you know any way to do this in Indesign? If not, may be the developers start to think on it.
      Thanks.
        • 1. Re: break apart
          Steve Werner Adobe Community Professional & MVP
          Since I'd consider that a narrow feature, it's not something that would probably be implemented in InDesign itself. If there were interest, someone would probably create a script to do that and make it available for users. InDesign is highly scriptable.
          • 2. Re: break apart
            For special typographic effects you can select the text and convert it to outlines (Type>Create Outlines) followed by releasing the compound paths (Object>Paths>Release Compound Paths) if you want the characters to be individual objects. Letters with counters will have to be reset to compounds via Pathfinder's Subtract. So:
            Can be converted to
            • 3. Re: break apart
              winterm Level 5
              Steve Werner wrote:
              ... someone would probably create a script to do that ...
              At least, THERE IS already a javascript, that splits text frame to separate text frames, each for one line.
              Written by Chinnadk in 2014.
              Edit:
              Ah, I even found a thread about it
