1 Reply Latest reply on Apr 12, 2016 6:51 AM by Rocketdrive
    What is the command hooks form?
    Ippodamo
      Hello!
      Maybe it's a simple thing, but I did not understand what is the command snap form (In Italian "aggancia forma") that is present in the preferences menu, with the 30° 45° 90° degrees?
      Thanks so much
      Giovanni
        • 1. Re: What is the command hooks form?
          Rocketdrive Level 2
          You can use so called Shapes like rulers or forms to draw on - like in real world.When using Shapes (or forms) from the menu, You can scale and rotate them before drawing. When rotation is close to 30°, 45° or 90° degrees, it snaps to that angle like a magnet. Try this with the ruler (the two parallel lines).
