• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Wrong TOC
Explorer ,
Apr 12, 2016 Apr 12, 2016
I copied the folder of another project. Added and removed what I needed for the new project, renamed it. I even deleted the old TOC, but the original TOC keeps coming up instead of the new TOC. How can I prevent this?
Views
378
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Apr 12, 2016 Apr 12, 2016
Sooo, when you examine the properties of the Printed Documentation layout, you have an opportunity to choose the TOC you wish to use. Are you certain you are using the correct TOC?
Assuming you only have one TOC defined or that you are certain you have the correct TOC selected, click Next >
And here you see what may be included from the TOC. If you have created Printed Documentation at least once, then later added topics, perhaps you need to ensure you also add them to the layout.
Cheers... Rick
Votes
Translate
Translate
Community Expert ,
Try deleting the .cpd file in the project already?
Votes
Translate
Translate
Report
Report
Explorer ,
I think I did delete the .cpd file because I can't find it.
Votes
Translate
Translate
Report
Report
Community Expert ,
It would get recreated when you started up RH again.
Votes
Translate
Translate
Report
Report
Community Expert ,
Have you applied the new TOC in the print layout?
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 13, 2016 Apr 13, 2016
To add to my earlier reply, when you create the Printed Documentation layout, it takes the TOC as it is then as the default. Then if you make changes to the TOC they are not automatically applied to the print layout, for good reasons.
Maybe you need to update the print layout. Use the left right chevrons or look for topics that are missing or not highlighted blue.
See Printed Output for more details. The RoboHelp 11 page also applies to RoboHelp 2015.
@petergrainge
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Many places to check. First off, what is the output? That will have some bearing on it.
Additionally, where are you looking at it?
* Immediately after generating content?
* After publishing to the final destination (Web Server, Local PC, Etc)
Once we know these answers we will be able to guide you a bit more clearly.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
I published both the primary WebHelp, then the printed output. Funny this is the WebHelp has the correct TOC, but the printed version does not. I'm viewing it after it's published to my laptop.
Votes
Translate
Translate
Report
Report
LEGEND ,
Cheers... Rick
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 14, 2016 Apr 14, 2016
LATEST
I think I got it I changed the layout and reviewed the output, and got what I needed. Thanks Guys!
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
