1 Reply Latest reply on May 5, 2006 12:02 PM by Newsgroup_User
    Zooming In and Out
    flying_scott
      Well, I know I am a novice, but my problem seems so simple and yet... it doesn't work.
      Check this code out:
      onLoad = function () {
      mcChart._xscale = 25;
      mcChart._yscale = 25;
      function doScaleUp() {
      mcChart.onEnterFrame = function() {
      if (mcChart._yscale<=300 && mcChart._xscale<=300) {
      mcChart._yscale += 5;
      mcChart._xscale += 5;
      function doScaleDown() {
      if (full == true) {
      if (mcChart._yscale>=25 && mcChart._xscale>=25) {
      mcChart._yscale -= 5;
      mcChart._xscale -= 5;
      bnZoomIn.onPress = function() {
      doScaleUp();
      bnZoomOut.onPress = function() {
      doScaleDown();
      mcChart.onPress = function() {
      startDrag(this);
      mcChart.onRelease = function() {
      stopDrag();
      The zooming in part works perfect, but the zoom out does NOTHING! what the heck am I missing???
      Thanks in advance!
      SA
        • 1. Re: Zooming In and Out
          Level 7
          flying_scott,
          Your problem doesn't work? I'm pretty sure you mean your goal
          doesn't work.
          Heck, man, it doesn't do nothing. It does something -- just not what
          you expect.
          Take a look at your zoom in code:
          This set in motion a frame loop (MovieClip.onEnterFrame) that never
          ends. Sure, your clips will stop sizing bigger until width and height are
          higher than 300, but the loop continues, which burns unnecessary CPU cycles.
          Note, too, that you can (should) refer to mcChart with the "this" operator.
          Why not something like this, instead:
          if (this._yscale<=300 && this._xscale<=300) {
          this._yscale += 5;
          this._xscale += 5;
          } else {
          delete this.onEnterFrame;
          Now, why is your zoom out not behaving as expected? Well, you've cause
          the whole function to depend on an if statement ...
          if (full == true) { ... }
          Where is this full variable declared? I didn't see any mention of full
          in your code except here, which means full is undefined (and hence, false).
          Since the if statement never evaluates to true, the mcChart frame loop never
          occurs.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
