5 Replies Latest reply on Apr 19, 2016 12:48 AM by BGVentuz
    Premiere Pro Importer: duration dependent on prefs
    BGVentuz
      I implemented an importer which calculates the duration of the imported clip using prefs which can be changed by the user. This works if only a single instance of the imported clip is present.
      When multiple instances of the clip are present and each one has different duration because of different prefs, Premiere sets the last calculated duration to all instances of the clip.
      Why does Premiere think that the duration of a clip is always independent of the stored preferences?
      What can I do?
      Best Regards
      -Bjoern Gdanietz-
        • 1. Re: Premiere Pro Importer: duration dependent on prefs
          Bruce Bullis Adobe Employee
          PPro doesn't think anything; it asks your importer.
          The behavior you've described doesn't sound like the behavior of the SDK's SDK_Importer sample; why and where does your plug-in's behavior, depart from the sample? Is yours a synthetic importer? Stills?
          • 2. Re: Premiere Pro Importer: duration dependent on prefs
            BGVentuz Level 1
            My importer is like the custom importer but instead of modifying the imported file, the changes are stored in the prefs of the imported clip instance.
            The importer is a generator for graphical overlays (lower thirds and such).
            A given file contains all information necessary for animating and rendering the overlay. (Textures, Geometries, Animation, Text and Timing for In/Pause/Out state)
            So the file itself represents a basis for the graphics to be generated.
            The workflow is the following:
            - You choose your template file and drag it into Premiere.
            - Doubleclick on the clip to change text and timing. (Stored in the prefs of the clip.)
            - Use the clip in the sequence.
            - If you need to change text and timing again ... go back two steps.
            If you need a second instance of the clip with different text and or timing, just import it again and configure it by double clicking.
            And there is my problem:
            The duration set in SDKFileInfo8->vidDuration during the imGetInfo8 call is automatically set to all instances. But the instances themselves would each report a different duration because of the data stored in their prefs.
            Lets imagine we have three instances of the same clip with different configured timings:
            A: 2s
            B: 1s
            C: 3s
            And the last clip you modified using the setup is B.
            Now all instance are reported to have the duration of 1s.
            Even worse:
            You don't have to have multiple instances of the clip in your project to reproduce this behavior. Just use the media browser to preview your clip and the resulting call to imGetInfo8 (for the preview instance without prefs) will reset the durations of the instance in your project (with prefs).
            If you have set the SDKFileInfo8->mayBeGrowing flag to true the media browser will reset your duration periodically.
            But PPro is misenterpreting my answer.
            It asks my importer: "How long is this clip when using these preferences?"
            And it's using the answer for all clips ignoring the different preferences.
            • 3. Re: Premiere Pro Importer: duration dependent on prefs
              You've successfully exceeded my (stale, old) Importer API depth!
              Zac Lam knows more...
              • 4. Re: Premiere Pro Importer: duration dependent on prefs
                Zac Lam Adobe Employee
                Hi Bjoern,
                I see the problem you're seeing.  Our titler behaves differently, and more like you're expecting, which is a good case for our importer API to follow the same approach.
                Good feature request.
                • 5. Re: Premiere Pro Importer: duration dependent on prefs
                  BGVentuz Level 1
                  Should I request this feature somewhere somehow
                  or is it already filed and I can lean back and wait for the next version of the API?
