4 Replies Latest reply on Apr 20, 2016 11:16 AM by S Hopkins
    Is there a script that can chang Multiple object into same width(I need width)?
    喜狼_edny Level 1
      For example,I want to Change 3 object's width to 40mm, also,Their high is changed with wide
      It can also be applied to the picture,and object.
      Thanks~~
      I've asked for a long time before, but I can't set my value.
        • 1. Re: Is there a script that can chang Multiple object into same width(I need width)?
          dnyaneshlb Level 1
          Hello,
          I am not InDesign developer but I write scripts for Illustrator. I think its straight forward.
          var  doc = app.activeDocument;
          var items = doc.groupItems;
          for(var index=0; index<items.length; index++)
               var item = items[index];
               item.width = 40;
               item.height = 30;
               if(index=0)
                    item.top = 0;
                    item.left = 0;
               else
                    item.top = 0;
                    item.left = items[index-1].width+10; // 10 is spacing you want in terms of pixels
          This is vague code I have written (not tested). There can be syntax errors. But all in all the script is self explanatory.
          Cheers,
          Dnyanesh
          • 2. Re: Is there a script that can chang Multiple object into same width(I need width)?
            喜狼_edny Level 1
            Thankyou very much,dnyaneshlb
            but it dosn't work~~
            • 3. Re: Is there a script that can chang Multiple object into same width(I need width)?
              Stefan Rakete Level 2
              for the horizontal distribution:
              var curDoc = app.activeDocument;
              var itemsToDistribute = curDoc.pageItems;
              var gap = 5;
              curDoc.distribute(itemsToDistribute, DistributeOptions.HORIZONTAL_SPACE, undefined, true, gap);
              • 4. Re: Is there a script that can chang Multiple object into same width(I need width)?
                S Hopkins Adobe Community Professional
                It seems to me that your big problem is in resizing the items before distributing. The following script may be helpful. You may also want to check out my blog for today that discusses some of the problems you may encounter in working with align distribute (yourscriptdoctor.com/blogs)
                set gap to 10
                  try
                  set keyObject to missing value
                  tell application "Adobe InDesign CC 2015"
                tell script preferences to set measurement to millimeters
                set docRef to active document
                --set selList to my pageItemsSelected()
                tell docRef
                set selList to selection
                if length of selList > 2 then
                set testItem to selection key object
                if testItem is not nothing then
                set keyObject to testItem
                set origBounds to geometric bounds of keyObject
                end if
                distribute align distribute items selList distribute option horizontal space align distribute bounds item bounds absolute distribute measurement 5 with use distribute measurement
                end if
                end tell
                if keyObject is not missing value then
                --using original bounds of selection key object to move selected items
                set newBounds to geometric bounds of keyObject
                if (item 2 of newBounds > item 2 of origBounds) then
                set relMove to (item 2 of newBounds) - (item 2 of origBounds)
                else
                set relMove to (item 2 of origBounds) - (item 2 of newBounds)
                end if
                move selList by {relMove, 0}
                end if
                end tell
                  on error (errStr)
                activate
                display alert "Error: " & errStr
                  end try
                  (*Returns reference to page items selected if more than 1; otherwise throws error*)
                  on pageItemsSelected()
                set errStr to "Requires a selection of 2 or more page items"
                if length of selList < 2 then
                error errStr
                end if
                set selItem to item 1 of selList
                if class of selItem is not in {text frame, rectangle, oval, polygon} then
                error errStr
                end if
                end tell
                return selList
                  end pageItemsSelected
