4 Replies Latest reply on Dec 13, 2016 8:00 PM by JMontray
    AfterFX.exe won't shut down
    JMontray
      After quitting After Effects the AfterFX.exe processes (8 of them on my system) won't shut down. This just started happening recently. After Effects version 5.5...
        • 1. Re: AfterFX.exe won't shut down
          You have not provided any useful technical information like system specs, error messages or whatever and if you really mean version 5.5 from ca. 2001, then I'm not sure what to tell you to begin with...
          Mylenium
          • 2. Re: AfterFX.exe won't shut down
            JMontray Level 1
            Sorry I should have provided more info...
            Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.160211-0600)
                       Language: English (Regional Setting: English)
                           BIOS: Bios Version:  1.03.5396
                      Processor:2/ Intel(R) Xeon(R) CPUs           E5450  @ 3.00GHz (8 CPUs), ~3.0GHz
                         Memory: 24576MB RAM
            Available OS Memory: 24574MB RAM
                        DirectX Version: DirectX 11
            Display Devices
                      Card name: NVIDIA GeForce GTX 580
                   Manufacturer: NVIDIA
                      Chip type: GeForce GTX 580
                       DAC type: Integrated RAMDAC
                      Display Memory: 4048 MB
               Dedicated Memory: 1488 MB
                  Shared Memory: 2559 MB
                   Current Mode: 1920 x 1200 (32 bit) (59Hz)
            The program shuts down, but the AfterFX.exe's still run. If I start After Effects again it starts a whole new set of AfterFX.exe's, as if it was not running. So I end up with 16 AfterEX.exe's running. I am able to stop the processes manually.  I am running it in multiple CPU render mode. Everything seems to work fine and I have had no crashes or freezes. As I said this has just recently been happening and I don't know what has changed. Yes this is an older version of AFX, but it is all I have at the moment. Thank you for your reply and I am hoping somebody can help me with this bug. It is not a big problem, just annoying....
            • 3. Re: AfterFX.exe won't shut down
              Do you actually mean AE version 5.5 or do you mean CS5.5 (which is AE version 10.5)?
              If CS5.5, what are your memory and multiprocessing settings?
              There was a bug fix update for CS5.5. Have you installed it? After Effects CS5.5 (10.5.1) update (unlikely to fix your current issue, but it wouldn't hurt to at least download the update if you haven't already).
              • 4. Re: AfterFX.exe won't shut down
                JMontray Level 1
                It is CS5.5 with all the updates. Memory installed 24GB. RAM reserved 3GB. Render Multiple Frames. RAM allocation 2GB per CPU. CPU's used 7.
                Installed RAM: 24.00 GB    Current RAM Usage: 1.41 GB    Allowed RAM Usage: 21.00 GB
                Process ID    Application Name    Min Needed Memory    Max Usable Memory    Max Allowed Memory    Current Memory    Current Priority
                68196    aeselflink    2.00    2.00    2.00    0.17
                70272    aeselflink    2.00    2.00    2.00    0.17
                71012    aeselflink    2.00    2.00    2.00    0.16
                72508    After Effects    0.40    24.00    21.00    0.25    1 - High
                76076    aeselflink    2.00    2.00    2.00    0.16
                76164    aeselflink    2.00    2.00    2.00    0.17
                77068    aeselflink    2.00    2.00    2.00    0.17
                81372    aeselflink    2.00    2.00    2.00    0.16
