4 Replies Latest reply on Apr 14, 2016 10:51 AM by Laubender
    app.select with group problem
    akiva_atwood Level 1
      I'm having a problem with selecting groups in a script: when I use app.select it selects the COMPONENTS of the group, not the group itself.
      myGroup=[]
      myGroup.push(obj1);
      myGroup.push(obj2);
      currentPage.groups.add(myGroup);
      which creates the group.
      app.select(myGroup)
      does NOT select the group -- instead i selects obj1 and obj2
      (I want to make the group an anchored object, so I need to select, cut, select insertionPoint, paste -- but you can't paste 2 selected objects...)
      Anyone now what's wrong?
        • 1. Re: app.select with group problem
          Vamitul Level 4
          myGroup=[]
          myGroup.push(obj1);
          myGroup.push(obj2);
          myInddGroup=currentPage.groups.add(myGroup);
          app.select(myInddGroup)
          ___edit__
          Take note that using things like copy() and paste() is quite a bad way to do a script.
          Better would be something like:
          myInddGroup.anchoredObjectSettings.insertAnchoredObject(insertionPoint, AnchorPosition.INLINE_POSITION);
          • 2. Re: app.select with group problem
            Hi Akiva,
            your variable myGroup is a simple Array object where two pageItems seem to be stored.
            If you do app.select(myGroup) you infact do:
            app.select([pageItem,pageItem]);
            and that will select the listed items, not the group you are building out of them.
            Just change the names of the variables to see this more clearly:
            var myArrayOfPageItems = [];
            myArrayOfPageItems.push(obj1);
            myArrayOfPageItems.push(obj2);
            // the method add() of object Group returns a Group object:
            var myGroup = currentPage.groups.add(myArrayOfPageItems);
            app.select(myGroup);
            And if you want to anchor the group, you could use the anchoredObjectSettings of the group like that:
            // Tested with values in millimeters
            var doc = app.documents.add();
            var pageItemOne = doc.rectangles.add({geometricBounds : [0,0,20,20]});
            var pageItemTwo = doc.rectangles.add({geometricBounds : [20,20,40,40]});
            var group = doc.pages[0].groups.add( [ pageItemOne , pageItemTwo ] );
            var textFrame = doc.textFrames.add({geometricBounds : [ 50,50,100,100 ] });
            var insertionPoint = textFrame.insertionPoints[0];
            // InDesign CS5.5 and above:
            group.anchoredObjectSettings.insertAnchoredObject(insertionPoint , AnchorPosition.ANCHORED);
            Hope that helps,
            Uwe
            • 3. Re: app.select with group problem
              Thanks -- I can't believe I made that mistake...
              • 4. Re: app.select with group problem
                Hi Vamitul,
                yes indeed and while working with selections one has to work within a single spread, because InDesign cannot select pageItems simultaniously on different spreads. Also, InDesign Server does know nothing about active objects or selections.
                Uwe
