1 Reply Latest reply on Apr 20, 2016 5:09 AM by natrev
    Create folder in last used folder loacation (aka current folder)
    salvadorr76775311
      HI,
      I am stuck with a part of my script.
      After the script has done a whol lot of work to multiple files I would like it to run the following script tosave a jpeg of the file in a folder called Print. This folder needs to be created in the current folder that was last used by photoshop. I looked in the discussion boards but could not find what I needed.
      I tried the:
      // getting the name and location;
      var docName = thedoc.name;
      if (docName.indexOf(".") != -1) {var basename = docName.match(/(.*)\.[^\.]+$/)[1]}
      else {var basename = docName};
      // getting the location, if unsaved save to desktop;
      try {var docPath = thedoc.path}
      catch (e) {var docPath = "~/Desktop"};
      // create folder if it does not exist;
      var folderString = docPath+"/"+basename;
      if (Folder(folderString).exists == false) {new Folder(folderString).create()};
      But this only works if the file has already been saved somewhere. This is not the case and I also do nit want to save the PSD first.
      So I Tried the folder.current approach but I do not get the results I am looking for. Any help would be appreciated.
      var idsave = charIDToTypeID( "save" );
      var desc9 = new ActionDescriptor();
      var idAs = charIDToTypeID( "As  " );
      var desc10 = new ActionDescriptor();
      var idEQlt = charIDToTypeID( "EQlt" );
      desc10.putInteger( idEQlt, 12 );
      var idMttC = charIDToTypeID( "MttC" );
      var idNone = charIDToTypeID( "None" );
      desc10.putEnumerated( idMttC, idMttC, idNone );
      var idJPEG = charIDToTypeID( "JPEG" );
      desc9.putObject( idAs, idJPEG, desc10 );
      var idIn = charIDToTypeID( "In  " );
      var basePath = Folder.current;
      var folderString = new Folder(basePath + "/Print");
      desc9.putPath( idIn, new File( "" ) );
      var idDocI = charIDToTypeID( "DocI" );
      desc9.putInteger( idDocI, 35 );
      var idsaveStage = stringIDToTypeID( "saveStage" );
      var idsaveStageType = stringIDToTypeID( "saveStageType" );
      var idsaveSucceeded = stringIDToTypeID( "saveSucceeded" );
      desc9.putEnumerated( idsaveStage, idsaveStageType, idsaveSucceeded );
      executeAction( idsave, desc9, DialogModes.ALL );
        • 1. Re: Create folder in last used folder loacation (aka current folder)
          natrev Level 3
          Hi Salvadorr,
          Try this code..
          var thedoc=app.activeDocument;
          var theCopy = thedoc.duplicate(basename,false);
          OutFoldPSD(folderString+"/Print",basename,true,true,Extension.LOWERCASE);
          theCopy.close(SaveOptions.DONOTSAVECHANGES);
          OutFoldJPEG(folderString+"/Print",basename,12,true,MatteType.NONE,Extension.LOWERCASE);
          function SaveJPEG(saveFile, jpegQuality,cProfile,MType,fCase){//12,true,MatteType.NONE
              jpgSaveOptions = new JPEGSaveOptions();
              jpgSaveOptions.embedColorProfile = cProfile;
              jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
              jpgSaveOptions.matte = MType; //MatteType.NONE
              jpgSaveOptions.quality = jpegQuality; //1-12
              activeDocument.saveAs(saveFile, jpgSaveOptions, true,fCase);
          function OutFoldJPEG(docPath,dnme,jpegQuality,cProfile,MType,fCase){
              var outfolder = new Folder(docPath)
              if (outfolder.exists == false){
                   outfolder.create();
                   var saveFile = new File(outfolder + "/" + dnme);
                  SaveJPEG(saveFile, jpegQuality,cProfile,MType,fCase);}
              else{
          function SavePSD(saveFile,cProfile,alphaCh,fCase){
              psdSaveOptions = new PhotoshopSaveOptions();
              psdSaveOptions.embedColorProfile = cProfile; //false
              psdSaveOptions.alphaChannels = alphaCh;  //false
              activeDocument.saveAs(saveFile, psdSaveOptions, true, fCase);
          function OutFoldPSD(docPath,dnme,cProfile,alphaCh,fCase){
              var outfolder = new Folder(docPath);
                   outfolder.create();
                  SavePSD(saveFile,cProfile,alphaCh,fCase);}
              else{
