Good Afternoon!
I created a drag and drop in Captivate 8 that has 2 targets and 4 drag sources. 3 of the sources go to 1 target and 1 source to the other. What I am trying to do is:
1. When the first source is dropped the next on the list appears and so on for the 4 options.
2. When the user clicks the submit button a "Congratulations" message appears.
3. When the wrong answer is dropped, the source snaps back into the list.
I've tried so many different configurations....any help is much appreciated.
Wanted to double-check, so I created a short project with
I do not understand the first question at all, can you explain more?
For the second question: Success message is missing indeed. You have to use the Success action of the Drag&Drop (actions tab) to show a previously hidden 'Congratulations' message. More info in this blog post:
Drag&Drop tips - Captivate blog
For the third question: you will have to edit the Object actions dialog box for each of the drop targets. By default they are set to Accept All drag sources, this has to be changed: uncheck the option 'Accept All' and indicate which drag sources can be accepted. The wrong ones will snap back to their original position (again I don't know what you mean by 'list').
Thank you!! Here is a screen shot of my drag and drop slide. When the learner first lands on the slide I would like only 1 box to show. When that box is dropped to a target, the next box will display, etc. Is there a way to do that or am I being too complicated?
As for the Message that has to appear, I explained in the blog post (first one) how to create a Success Message. BTW that Success message is now available out of the box in CP9.
Thank you so much!! Your advice is much appreciated!
Jen
You're welcome. I was not sure that a 'hidden' object would be accepted as drag source, now found out that it is! Learned something extra myself.
