1 Reply Latest reply on Apr 19, 2016 4:32 PM by williamadowling
    script to save svg to pdf
    karth80472045 Level 1
      hello sir /madam
      i have 100 svg files in folder , for this files it should save as pdf according to artboard size with same file name
        • 1. Re: script to save svg to pdf
          williamadowling Level 4
          You can easily do this with actions. No scripting necessary.
          Create an action that saves a PDF and apply your desired PDF save settings. Then from the actions panel, click the menu at the top right and click "Batch". Set the source folder to your folder of SVGs and set the destination folder to an empty folder where you want your PDFs to go. Select the action you created for saving PDFs and then run the batch.
          This will be exponentially easier than trying to write javascript/applesctript/vbs to do the same task.
