1 Reply Latest reply on May 4, 2006 9:31 AM by drumkeyjw
    Importing Alpha Channel into Flash 8 using Final Cut Pro Express HD
    drumkeyjw
      hey all...
      i know this is a Flash forum, but this problem is really getting to me.
      ok, I have a .dv file that I key out in Fincal Cut Express HD. I then Export in Final Cut Express using Quick Time Conversion and selecting the FLV format. I make sure to check the "Encode Alpha Channel" button and then I export it.
      When I bring it into Flash 8, I have solid black where there should be transparency in the video. Here are the steps I am using:
      1. Import the .dv file in Final Cut Express HD
      2. Apply 4:1:1 smoothing
      3. Chroma Keyer
      4. 8-Point Garbage Matte
      5. Render Video and Audio
      6. Export as .flv with "Encode Alpha Channel" checked
      7. Import the .flv into Flash 8
      8. Place instance on the stage
      Where am I going wrong?
      Any help would be greatly appreciated. I did get this to work one time, but the next day no luck.
      -john
