2 Replies Latest reply on Apr 18, 2016 5:13 AM by xXdab0mbXx
    Clips invisible
    xXdab0mbXx Level 1
      I have the latest version of After Effects on my PC. I imported my Premiere project using Replace with After Effects Composition. For some reason, the clips seem to be invisible! Everything was untouched from the Premiere project.
        • 1. Re: Clips invisible
          If you have done this before and it has worked then I have to ask what changed? What is different?
          If you have never done this before, did you follow the recommended procedure for using dynamic link or are you trying to import a Premiere Pro sequence directly into AE?
          If you followed normal procedures then there could be a problem with the format of your footage. Before we can help you we need details. Anything else is just a guess.
          • 2. Re: Clips invisible
            xXdab0mbXx Level 1
            I've tried the steps found in a vid2brain video. They said to select all the clips in the Premiere timeline then right-click, then press "Replace with After Effects Composition". The video files are in mov format, and I have QuickTime installed. There is also a title from Premiere linked to a picture in JPEG format. There is also some music from the Premiere project that I selected and it's in mp3 format. I have tried using Dynamic Link, but it made the sequence as one layer, which is what I did not want to do. I want it to show all clips in the timeline as layers.
