1 Reply Latest reply on May 3, 2006 7:37 AM by CraigCC
    printing bullet points
      I am creating web help projects using RoboHelp X5.0.2.
      I have created several custom styles that use graphical bullet points. The graphics are GIF, size 24 x 14 pixels (w x h).
      My problem is that while the bullets appear fine in print preview and on screen, when a topic is printed the bullets do not appear on the page. I have added the GIFs as baggage files but this makes no difference. If I switch the styles to use the built-in bullet points instead of GIFs, they print fine.
      What am I doing wrong?
        • 1. Re: printing bullet points
          CraigCC Level 2
          Hi Googun,
          I had a similar problem a few weeks ago.
          On investigation, the graphic (gif format) that was being used for the bullet point had a colour transparency value set (it was set the a value in the pallet entry). Once this was modified - i.e. set to 'No Transparency' the bullet graphic printed absolutely fine.
          Not sure which graphics application you have access to. As a guidance, in paintshop pro, you can modify the transparency value via the Colours menu - select the Set Palette Transparency option.
          Hope that helps
