2 Replies Latest reply on Apr 18, 2016 8:53 AM by maestro0784
    Redaction bug when using import .txt function (Acrobat Pro DC)
    maestro0784 Level 1
      I'm attempting to redact large sections of a document using the import .txt function to select sentences/phrases. It works great, except if there is a - or '. In that case, Acrobat mis-reads the text file, per the screenshot below. If I copy the sentence from the PDF, and add it in the same box manually, it appears fine. If I paste the same clipboard into a txt, and then import the text, it results in the mis-read and thus won't find the phrase in the document.
