7 Replies Latest reply on Apr 19, 2016 4:25 PM by rob day
    Can Display Performance affect Export PDF quality??
    crisdesgroot
      How can the quality of an Exported PDF  be affected by on-screen Display Performance ??
      This would sound completely counter-intuitive to anybody using Indesign - i guess.
      However, this is exactly what seems to have happened to me just now.
      I'm dropping an Illustrator-created-PDF into a frame in Indesign. And then exporting that as a Press Quality PDF.
      Done it a thousand times.
      But this time - the final , exported PDF from Indesign came out with a lo-res image where my beautiful illustration should have been.
      The illustrator PDF is still high quality.
      I've gone back in, and sure enough I can correct the problem by altering the 'Display Performance' setting before exporting from Indesign.
      I've never had this before - am I missing something?
      Is this a new feature ? or have i accidentally flicked an invisible somewhere else ?
      help !
      CRiS
        • 1. Re: Can Display Performance affect Export PDF quality??
          The display performance does not affect in anyway the PDF export.
          When it comes to LowRes PDFs such errors might have be done:
          1. Linked file is missing (Link Panel!)
          2. Linked file was edited (Link Panel)
          3. PDF was created via printing and some settings were wrong (Simple Solution: Export as PDF)
          4. PDF export settings were low res.
          5. Image was placed via copy & paste instead via File > Place…
          6. Linked file is damaged
          7. Server connection to the linked file was interrupted.
          • 2. Re: Can Display Performance affect Export PDF quality??
            crisdesgroot Level 1
            Thankyou Willi,
            And while i would largely agree with you , that those are typically what you'd expect , my experience in this instance differs .
            Once i saw the finished print job - i went back in and saw that my exported PDF was lo-res.
            I open up Indesign - and it's showing all links are healthy , but with the offending item at Fast (low) Display Perfomance.
            I click on 'high quality' display for the offending object, and export again.
            The offending element in the PDF now looks great.
            I can even go back , turn the display back to Fast, and re-export - getting the lo-res element back.
            I do however, now think that the Indesign file itself might be a bit glitchy as i can't repeat this effect when starting a new file.
            It's odd. I hope it doesn't happen again. It can lead to expensive mistakes. I will be super observant of all proofs in future!
            • 3. Re: Can Display Performance affect Export PDF quality??
              This could only happen, if you create your PDF via print. It cannot happen when you export your PDF.
              • 4. Re: Can Display Performance affect Export PDF quality??
                Willi,
                While your assertion is tru 99.9% of the time - this is computer software  -  so the words "cannot happen" are as incredible as they are ridiculous.
                I don't think anybody in their right mind would try to make the claim that software is infalliable - and never breaks down, crashes, or gets caught in loops.
                It's this kind of attitude : that the machine is always right : that frustrates the hell out of users and expert users alike.
                So unless you've got something smart to share - please contain your optimistic predictions of computational perfection to yourself.
                Next time something weird happens on my computer i'll remember to video it for your benefit .
                many thanks,
                CRiS
                p.s.
                This particular Indesign file still has strange characteristics - while the PDF illustrations from illustrator work perfectly.
                My PhD in UX design gives me some credibility when it comes to making observational claims about technological experiences.
                • 5. Re: Can Display Performance affect Export PDF quality??
                  crisdesgroot wrote:
                  … Once i saw the finished print job - i went back in and saw that my exported PDF was lo-res.
                  Hi CRiS,
                  is there a chance to test that particular InDesign document on my machine with OSX ?
                  Maybe by providing a download link via personal message (through this forum)?
                  I never heard of a case like this.
                  But I agree, that "nothing is impossible" with software… ;-)
                  Kind regards,
                  Uwe
                  • 6. Re: Can Display Performance affect Export PDF quality??
                    How are you checking the resolution of the objects in the exported PDF? If you check the offending object with AcrobatPro's Output Preview>Preview>Object Inspector are you getting different Image Attributes (size in pixel dimensions and resolution). For example:
                    If you are getting different resolutions maybe you could show us a capture of the attribute differences?
                    • 7. Re: Can Display Performance affect Export PDF quality??
                      Also, I would avoid the Press Quality preset which exports untagged CMYK with no indication of the output intent. PDF/X-4 would be a better choice—if you need all CMYK you can force all the color into the document's CMYK profile from the Output tab.
