4 Replies Latest reply on May 2, 2006 12:57 AM by Newsgroup_User
    middle point
    Level 7
      Hello,
      How do you do for center the middel point in the graphic ?
      thank you
        • 1. Re: middle point
          Level 7
          Dave,
          Is this an ActionScript question? (No sarcasm intended. I'm sincerely
          asking.)
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: middle point
            skullnz
            If you mean "how do you find the middle point in a movieclip" you can do it this way:
            var middle_x = this._width / 2;
            var middle_y = this._height / 2;
            • 3. Re: middle point
              Level 7
              no i would like change the middle point
              thank you
              thank you
              "skullnz" <webforumsuser@macromedia.com> a �crit dans le message de news:
              e354h1$lpl$1@forums.macromedia.com...
              > it this way:
              • 4. Re: middle point
                Level 7
                "Dave" <frsingles@ifrance.com> wrote in message news:e36opv$n6$1@forums.macromedia.com...
                > thank you
                > thank you
                > "skullnz" <webforumsuser@macromedia.com> a �crit dans le message de news: e354h1$lpl$1@forums.macromedia.com...
                Double-click on the object in the library (not the stage), then when you are editing the object, use the align tools with 'to stage'
                button turned on to center the object.
                tralfaz
