3 Replies Latest reply on Apr 20, 2006 11:28 PM by Newsgroup_User
    Control sound in timeline
    Level 7
      Hy,
      I've some mc called, one a time, with attachMovie named mcTarget, each of
      this has one speaker track sincronized with the animation on the stage. For
      this reason sound is put directly in timeline in stream mode
      (proprieties>>Sincr: stream). But now I cant control the volume of these
      sounds. I'll tryed to do this:
      //on main root
      mySound = new Sound(); //no specify target to refer a "global sound"
      function Volume(val){
      mySound.setVolume(val);
      trace(val);
      // in another place
      Volume(50);
      This works only with a sound placed in main root but does nothing if the
      sound is placed on a nested mc (my case).
      Someone have an idea or a alternative way to do this?
      Roger
        • 1. Re: Control sound in timeline
          sneakyimp Level 2
          mySound cannot be defined as an empty sound object. it has to refer to the soundclip in question.
          // NO
          // mySound is attempting to refer to *one specific sound*
          // *not* a global sound setting
          mySound.setVolume(50);
          // YES
          // this is referring to one particular sound
          this.MySound1.setVolume(50);
          I'm not sure how this relates to sounds added to the timeline. i think you have to use the flash authoring interface controls to do it. i *don't* think you can control sounds added this way with actionscript unless you can determine what their target path is.
          this may or may not be helpful:
          http://www.kennybellew.com/tutorial/multiple_scenes.htm
          • 2. Re: Control sound in timeline
            Level 7
            "sneakyimp" <webforumsuser@macromedia.com> ha scritto nel messaggio
            news:e1kumu$sv6$1@forums.macromedia.com...
            > the
            This is the "canonic way", but you can use that code to do a something near
            at "global sound"
            you can see it also in at http://www.kennybellew.com/tutorial/globally.htm.
            > // NO
            > // YES
            > you
            > think
            Sure, it's works with sound put in a root timeline..
            Thanks, but I didn't find the solution for my case...
            many thanks for the answer.
            • 3. Re: Control sound in timeline
              Level 7
              "arp" <arp@stong.de> ha scritto nel messaggio
              news:e1ks3c$q5f$1@forums.macromedia.com...
              Any idea?
