• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Have object - want that user sees selection
Community Expert ,
Apr 19, 2016 Apr 19, 2016
Dear experts,
I'm down in the object store and have found a marker. I want that the user sees in the document, what I have found.
The problem is: how to come from an object to a TextSelection and TextLocation? All I have found goes the other way round.
currentMarker = GetFirstMarker (doc, "#calc"); // this does its job
doc.TextSelecton = currentMarker;              // no error, no effect
doc.ScrollToText(...);                         // requires TextLocation
I have studied more than one diagram of the DOM but still don't see through the fog.
Klaus
TOPICS
Scripting
Views
576
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Apr 19, 2016 Apr 19, 2016
Hi Klaus,
I have to say sorry. I was lacking in concentration.
Here the right solution. (I hope, this time with better concentration)
This is the way:
you get the textlocation.
you create a textrange.
you select the text.
var tloc1 = currentMarker.TextLoc;
var tloc2 = currentMarker.TextLoc;
tloc2.offset = tloc2.offset+1;
var myTextRange  = new TextRange(tloc1,tloc2);
doc.TextSelection = myTextRange ;
doc.ScrollToText (myTextRange );
Votes
Translate
Translate
Enthusiast ,
Hi Klaus,
that should work:
var tloc = currentMarker.TextLoc;
var tlocStart = new TextLoc(currentMarker.TextLoc.beg.obj,currentMarker.TextLoc.beg.offset);
tlocEnd.offset = tlocEnd.offset + 1; // if you want to select the marker
var tlocEnd = new TextLoc(currentMarker.TextLoc.end.obj,currentMarker.TextLoc.end.offset);      // beg and end  have the same value, but this is to show the complete way
var myTextRange = new TextRange (tlocStart, tlocEnd);   // define a TextRange
doc.TextSelection = myTextRange;  // if you want to select the marker
doc.ScrollToText(myTextRange);                         // requires a TextRange. NOT a location
In your code line 3 you have to use a TextRange.
This TextRange you get from your Marker's TextLoc (marker.TextLoc)
Votes
Translate
Translate
Report
Report
Community Expert ,
Thanks Klaus,
Not relevant: line 1 is dangling in the air - tloc not used any further.
More delicate: currentMarker.TextLoc.beg.obj creates "undefined is not an object".
but currentMarker.beg.obj creates the same error, as I tried in the following code to have more steps to walk through:
function DisplayMarker (oDoc, currentMarker) {
  var begObj    = currentMarker.TextLoc.beg.obj;
  var begOffset = currentMarker.TextLoc.beg.offset;
  var tlocStart = new TextLoc(begObj, begOffset);
  var tlocEnd =   new TextLoc(currentMarker.TextLoc.end.obj, currentMarker.TextLoc.end.offset);
  oDoc.TextSelection = myTextRange;               // if you want to select the marker
  oDoc.ScrollToText(myTextRange);                 // requires a TextRange. NOT a location
Still confused, but on a higher level ...
Klaus
Votes
Translate
Translate
Report
Report
Enthusiast ,
Hi Klaus,
This is the way:
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 20, 2016 Apr 20, 2016
LATEST
Yes, Klaus, your concentration was excellent!
  tloc2.offset = tloc2.offset+1;                 // offset2 = offset1 is given by TextLoc
  var myTextRange  = new TextRange(tloc1,tloc2); // define a TextRange
The marker becomes selected in line 7, before the function is left:
Votes
Translate
Translate
Report
Report
