• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Captivate settings exporting for Succesfactors LMS
Explorer ,
Apr 19, 2016 Apr 19, 2016
My client use the Succesfactors LMS which is compatible with Captivate. I made a project with Captivate 9. You can see my LMS settings in the images below:
Screen Shot 2016-04-19 at 16.44.08.pngScreen Shot 2016-04-19 at 16.44.21.png
My client says the following problem shows up when he tries to upload my published file:
I tried some different settings but they all won't work. Does anyone can help me out on this one?
TOPICS
Quizzing and LMS
Views
307
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Apr 20, 2016 Apr 20, 2016
My client already has the solution. The problem was the map structure. The following map structure didn't work:
.ZIP File
.Projectname
- All captivate published files
The LMS could not found the XML manifest.
The mapstructure has to look like this so the XML manifest is directly in the .ZIP File
.ZIP File
Votes
Translate
Translate
Community Expert ,
Can you try to upload the published SCO-folder (zipped folder) to Scorm Cloud to see if it is functional there, to see if the issue is with Captivate or with the LMS?
BTW I would never put that slide percentage at 100%.
Votes
Translate
Translate
Report
Report
Explorer ,
.ZIP File
.Projectname
.ZIP File
Votes
Translate
Translate
Report
Report
Community Expert ,
If you publish from Captivate to a SCO, manifest file is included in zipped
folder.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Your screenshot shows you as having selected AICC as the LMS integration standard for your output when it appears from your LMS error message that it was expecting to find a SCORM file.  AICC doesn't use an imsmanifest.xml.
So which are you wanting to use, AICC or SCORM?
Votes
Translate
Translate
Report
Report
Resources
Help resources
