7 Replies Latest reply on May 7, 2016 5:33 AM by Davmi
    Checking if layer is visible and run a function depending on answer
    Davmi
      Hey guys,
      I've got a question that's been racking my brain the last few days.
      So I want to run a script when I press a button that will check if a specific layer is visible. If yes, it will execute another function that shows additional layers. If the specific layer is not visible, it checks the next layer to see if that is visible. This continues until it checks all required layers and finds a visible layer.
      Here's the script in question:
      #target photoshop
      // clthTopTt.jsx
      cTID = function(s) { return app.charIDToTypeID(s); };
      sTID = function(s) { return app.stringIDToTypeID(s); };
      //==================== actnStd ==============
      function checkactnStd() {
        // Select
        function step1(enabled, withDialog) {
          if (enabled != undefined && !enabled)
            return;
          var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
          var desc1 = new ActionDescriptor();
          var ref1 = new ActionReference();
          ref1.putName(cTID('Lyr '), "actnStd");
          desc1.putReference(cTID('null'), ref1);
          desc1.putBoolean(cTID('MkVs'), false);
          var list1 = new ActionList();
          list1.putInteger(17011);
          desc1.putList(cTID('LyrI'), list1);
          executeAction(cTID('slct'), desc1, dialogMode);
        // If
        function step2(enabled, withDialog) {
            return;
          desc1.putEnumerated(cTID('null'), cTID('Cndt'), cTID('Vsbl'));
          ref1.putName(cTID('Actn'), "select actnStd");     <------- If the actnStd layer is visible, instead of running this action, it runs the selectactnStd() function.
          ref1.putName(cTID('ASet'), "clthTopTt");
          desc1.putReference(cTID('then'), ref1);
          var ref2 = new ActionReference();
          ref2.putName(cTID('Actn'), "check actnWlk");  <------- If the actnStd layer is NOT visible, it runs the checks the next layer (via the checkactnWlk() function.
          ref2.putName(cTID('ASet'), "clthTopTt");
          desc1.putReference(cTID('else'), ref2);
          executeAction(sTID('conditional'), desc1, dialogMode);
        step1();      // Select
        step2();      // If
      function selectactnStd() {
        // Show
            return;
          ref1.putName(cTID('Lyr '), "topStdTt");
          ref1.putName(cTID('Lyr '), "topMskStd");
          list1.putReference(ref1);
          desc1.putList(cTID('null'), list1);
          executeAction(cTID('Shw '), desc1, dialogMode);
        // Hide
            return;
          ref1.putName(cTID('Lyr '), "topWlkTt");
          ref1.putName(cTID('Lyr '), "topMskWlk");
          ref1.putName(cTID('Lyr '), "topRunTt");
          ref1.putName(cTID('Lyr '), "topMskRun");
          executeAction(cTID('Hd  '), desc1, dialogMode);
        step1();      // Show
        step2();      // Hide
      //==================== actnWlk ==============
      function checkactnWlk() {
        // Select
            return;
          ref1.putName(cTID('Lyr '), "actnWlk");
          list1.putInteger(17012);
        // If
            return;
          ref1.putName(cTID('Actn'), "select actnWlk");
          ref2.putName(cTID('Actn'), "check actnRun");
        step1();      // Select
        step2();      // If
      function selectactnWlk() {
        // Show
            return;
        // Hide
            return;
        step1();      // Show
        step2();      // Hide
      //==================== actnRun ==============
      function checkactnRun() {
        // Select
            return;
          ref1.putName(cTID('Lyr '), "actnRun");
          list1.putInteger(17013);
        // If
            return;
          ref1.putName(cTID('Actn'), "select actnRun");
          ref2.putName(cTID('Actn'), "check actnAc");
        step1();      // Select
        step2();      // If
      function selectactnRun() {
        // Show
            return;
        // Hide
            return;
        step1();      // Show
        step2();      // Hide
      After it checks the last layer, it then ends the script.
      "clthTopTtLoop.jsx"
      // EOF
      Any help is seriously appreciated. Thanks guys!
        • 1. Re: Checking if layer is visible and run a function depending on answer
          natrev Level 3
          Hi Davmi,
          How do you identify the specific layer? any Special name or suffix / prefix / layer index no / position
          The below code is working whether if any layer visible execute the action "selectactnStd"
          else execute the action "checkactnWlk" action
          Code..
          #target photoshop
          if ( app.documents.length <= 0 ) alert( "No Image in Use" );
          else{main();}
          function main(){
              var docRef = app.activeDocument;
              var myLayers=docRef.layers;
              for(i=0; i<myLayers.length;i++){
                  if(myLayers[i].typename=="ArtLayer" && myLayers[i].visible==true && myLayers[i].name!="Background"){
                      alert("Layer is Visible");
                      docRef.activeLayer=myLayers[i];
                      app.doAction ('selectactnStd', 'Set 1'); //Action name and Action set or Action group name
                  else if (myLayers[i].typename=="ArtLayer" && myLayers[i].visible==false && myLayers[i].name!="Background"){
                      alert("Layer is inVisible");
                      app.doAction ('checkactnWlk', 'Set 1');//Action name and Action set or Action group name
                      myLayers[i].visible=false;
          -yajiv
          • 2. Re: Checking if layer is visible and run a function depending on answer
            Davmi Level 1
            Thank you so much for the reply, natrev.
            To give a little more background on what I'm trying to achieve:
            So right now as it stands, the script IS working that I posted my first post. The issue here is that I'd like to use functions instead of actions. It might seem like a hassle, but I'd like to circumvent my friends from having to download/rely on addition action (.atn) files if possible.
            My current script works like this at the moment:
            Select the layer named actnStd            (this is done with the checkactnStd() function).
            • If layer is visible, run the action to select set "clthTopTt" and action "select actnStd")
            • If layer is not visible, run the action to select set "clthTopTt" and action "check actnWlk") (which checks the next layer for visibility).
            Select the layer named actnWlk           (this is done with the checkactnWlk() function).
            • If layer is visible, run the action to select set "clthTopTt" and action "select actnWlk")
            • If layer is not visible, run the action to select set "clthTopTt" and action "check actnRun") (which checks the next layer for visibility).
            Select the layer named actnRun          (this is done with the checkactnRun(); function).
            • If layer is visible, run the action to select set "clthTopTt" and action "select actnRun")
            • If layer is not visible for any of the above, then stop the loop.
            This is the script that I want:
            • If layer is visible, run the function selectactnStd();     (This will basically show the layers I want and hide the layers I don't want and end the loop).
            • If layer is not visible, run the function checkactnWlk();      (This will move on to the next layer to check for visibilty).
            • If layer is visible, run the function selectactnWlk();    (This will basically show the layers I want and hide the layers I don't want and end the loop).
            • If layer is not visible, run the function checkactnRun();      (This will move on to the next layer to check for visibilty).
            • If layer is visible, run the function selectactnRun();
            • If layer is not visible, run the function checkactnFly();      (This will move on to the next layer to check for visibility and end the loop).
            Select the layer named actnFly          (this is done with the checkactnFly(); function).
            • If layer is visible, run the function selectactnFly();
            • If layer is not visible for any of the above layers, then stop the loop and show message saying something like "no layers selected".
            Is this possible? Again, any help is highly appreciated.
            • 3. Re: Checking if layer is visible and run a function depending on answer
              Chuck Uebele Adobe Community Professional & MVP
              You can pretty much record your actions as scripts by using scriptlistener to record the steps. Once you get the code for all that, the rest is pretty easy also. you just need to select the layers, by whatever means you want then check for the layer being visible:
              var doc = activeDocument;
              var theFirstLayer //get this however you want
              if(theFirstLayer.visible){
              //put function for if visible
              else{
              //put function if not visible, etc.
              • 4. Re: Checking if layer is visible and run a function depending on answer
                Davmi Level 1
                Thanks for the input Chuck.
                I hate to pester you, but can you possibly put it within the context of my first post? I understand the concept of what you're saying, but I just don't know enough about Javascript to properly formulate the script.
                • 5. Re: Checking if layer is visible and run a function depending on answer
                  natrev Level 3
                  Hi Davmi,
                  Try this code.
                  #target photoshop
                  else{main();}
                  function main(){
                           if (myLayers[i].typename=="ArtLayer" && myLayers[i].name!="Background"){
                            if(myLayers[i].name=="actnStd" && myLayers[i].visible==true){
                                  app.doAction ('select actnStd', 'clthTopTt'); //Action name and Action set or Action group name
                              else if (myLayers[i].name=="actnStd" && myLayers[i].visible==false){
                                  app.doAction ('check actnWlk', 'clthTopTt');//Action name and Action set or Action group name
                              else if(myLayers[i].name=="actnWlk" && myLayers[i].visible==true){
                                  app.doAction ('check actnWlk', 'clthTopTt'); //Action name and Action set or Action group name
                              else if (myLayers[i].name=="actnWlk" && myLayers[i].visible==false){
                                  app.doAction ('check actnRun', 'clthTopTt');//Action name and Action set or Action group name
                              else if(myLayers[i].name=="actnRun" && myLayers[i].visible==true){
                                  app.doAction ('select actnRun', 'clthTopTt'); //Action name and Action set or Action group name
                              else if (myLayers[i].name=="actnRun" && myLayers[i].visible==false){
                                  return;
                  -yajiv
                  • 6. Re: Checking if layer is visible and run a function depending on answer
                    Davmi Level 1
                    Thanks again natrev.
                    I haven't tried the code yet, but I ended up hiring a JavaScript Developer. He said my code was generic recorded code, so he'll clean it up and resend it to me. I'll post a response with a version of the code that will help others in the future with this issue. I'll also try your code just to get more familiar with it.
                    Again, I really appreciate all your help.
                    -Dave
                    • 7. Re: Checking if layer is visible and run a function depending on answer
                      Davmi Level 1
                      Hey guys, I promised I'd update this post to help others if I got the answer, so here goes:
                      First, the developer created a function to automatically get the layer. I was having problems figuring out how to select layers, particularly because the layers were nested in groups within groups. This helped resolve that. The function was this:
                      function selectLayer(name) {
                        var desc = new ActionDescriptor();
                        var ref = new ActionReference();
                        ref.putName( charIDToTypeID('Lyr '), name );
                        desc.putReference( charIDToTypeID('null'), ref );
                        desc.putBoolean( charIDToTypeID('MkVs'), false );
                        executeAction( charIDToTypeID('slct'), desc, DialogModes.NO );
                        return
                      You then call the layer by using the actual layer name (assuming your layer names are unique. If they are not, you'll only end up selecting the first layer with that specific name) throughout your script file.
                      IE. In my case, selectLayer("actnStd"); or selectLayer("actnWlk");
                      You then set the visibility using the following code:
                      // show
                      app.activeDocument.activeLayer.visible = true;
                      // hide
                      app.activeDocument.activeLayer.visible = false;
                      You then use a function to check if a layer is visible. If the layer is visible, you execute the function that shows/hides the respective layers:
                      function CheckactnWlk() {
                        if  (app.activeDocument.activeLayer.visible == true) {
                        SelectactnWlk()
                        else  {
                        CheckactnRun();
                      So in the end, the final script looks like this:
                      #target photoshop
                      app.bringToFront();
                      CheckactnStd();
                      function CheckactnStd() {
                        SelectactnStd()
                        else  {
                        CheckactnWlk();
                      function SelectactnStd() {
                        selectLayer("topMskStd");
                        selectLayer("topStdTt");
                        selectLayer("topWlkTt");
                        selectLayer("topMskWlk");
                        selectLayer("topRunTt");
                        selectLayer("topMskRun");
                        SelectactnWlk()
                        else  {
                        CheckactnRun();
                      function SelectactnWlk() {
                      function CheckactnRun() {
                        selectLayer("actnRun");
                        SelectactnRun()
                        else  {
                        alert ('There is no Selected Layer', 'Please select a layer', 0);
                      function SelectactnRun() {
                             return
                      app.preferences.rulerUnits = rUnit;
                      app.preferences.typeUnits = tUnit;
                      Good luck guys! Now on to figuring out how to select random layers via script.
